FPGA Intellectual Property
6670 Discussions
DDR3-IPcore clock frequency
hello everyone.
I have a little question about DDR3-IP core.
my environment is ...
FPGA: ArriaIIGX
QuartusII: version 13.0
IP: DDR3-SDRAM controller with ALTMEMPHY v13.1
I have set 100MHz for "PLL reference clock frequency" .
and memory clock frequency is 300MHz
and I input 100MHz to pll_ref_clk pin as I set above.
then this IP-core does not work ( init_done is stacking LOW ).
I had no idea about this and tried many things.
then I found that when I gave 50MHz clock to pll_ref_clk, DDR3-SDRAM works well.
the "PLL reference clock frequency" is still 100MHz.
I don't understand what happens.
can anybody tell what do I miss? or is that correct?
