FPGA Intellectual Property
6671 Discussions
DMA controller doesn't work properly
Hi everyone!
I'm confused, because I really tried everything I could, but the DMA does not work.
I use such functions:
* Set transmit channel
static inline void moveTo(dhdlc_t *dhdlc, void *ptr, size_t blocksize){
IOWR_ALTERA_AVALON_DMA_STATUS(DMA_0_BASE,0);
IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_0_BASE,ptr);
IOWR_ALTERA_AVALON_DMA_CONTROL (DMA_0_BASE, TXDMA_CONTROL);
IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_0_BASE, blocksize);
while ((IORD_ALTERA_AVALON_DMA_STATUS(DMA_0_BASE) & ALTERA_AVALON_DMA_STATUS_BUSY_MSK));
* Set receive channel
static inline void moveFrom(dhdlc_t *dhdlc, void *ptr, size_t blocksize){
IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_0_BASE,ptr);
IOWR_ALTERA_AVALON_DMA_CONTROL (DMA_0_BASE, RXDMA_CONTROL);
where:
# define TXDMA_CONTROL (ALTERA_AVALON_DMA_CONTROL_WORD_MSK |
ALTERA_AVALON_DMA_CONTROL_BYTE_MSK |
ALTERA_AVALON_DMA_CONTROL_HW_MSK |
ALTERA_AVALON_DMA_CONTROL_QWORD_MSK |
ALTERA_AVALON_DMA_CONTROL_DWORD_MSK |
ALTERA_AVALON_DMA_CONTROL_GO_MSK |
ALTERA_AVALON_DMA_CONTROL_LEEN_MSK |
ALTERA_AVALON_DMA_CONTROL_WCON_MSK)
* Receive control register setup macro
*/# define RXDMA_CONTROL (ALTERA_AVALON_DMA_CONTROL_WORD_MSK |
ALTERA_AVALON_DMA_CONTROL_RCON_MSK)
The read/write addresses are set in my function before the usage of move_ functions.
Reading from memory to a peripheral does work well. But writing from a peripheral is partially done and than the BUSY reg is set and the whole transmission gets stuck :/
I have to admitt that the DMA controller in Quartus Prime 16.1 standard edition does work only for maximum of 64 bursts for txchannel...
Have anyone had the same bug/problem as I?
I tried to use the Altera provided HAL functions, but register access works better.
