FPGA Intellectual Property
DSP Builder Diagram
Hello everyone,
Somebody can helpme to understand the diagram that I attached, I was simulating the diagram in the coutinuos time and the results is good, but I dont understand the results obtained with the diagram with Altera Blocks.
Please if you have any little comments, please make it.
Thankyou for check my problem ...
Jjeshua
Hi, You have first convert your continuous model to z-domain (discrete model) and then convert your new model to canonical form. You can get information from the following reference:
Gene F. Franklin, J.David Powell and Michael L. Workman, digital control of dynamic systems, 1998.
Hi lok,
Thank you!!! I will check the reference, but do think that the model in the Altera Block should be modified to be the same in the continuos time? sorry but i dont know, is my first time usng FPGA.
Thank you
Jjeshua
