Hello, I’m having a lot of trouble getting an output in the FPGA pin using a HIL (Hardware in the Loop) block using Altera Block set library in Simulink.
I made the design in the Simulink and compile and program without a problem, but when I replace it to the HIL block the inputs and outputs don’t get out of the FPGA Thanks for any help链接已复制
1 回复
