FPGA Intellectual Property
6670 Discussions
DSP Builder Hardware in the Loop / FPGA I/O pins
Hello, I’m having a lot of trouble getting an output in the FPGA pin using a HIL (Hardware in the Loop) block using Altera Block set library in Simulink.
I made the design in the Simulink and compile and program without a problem, but when I replace it to the HIL block the inputs and outputs don’t get out of the FPGA
Thanks for any help
I´m using a Cyclon IV E FPGA and have the same problem. Did you solve it?
I tried the examples out of the DSP Builder handbook, but non of them worked on my device/system...
