FPGA Intellectual Property
6670 Discussions
DSP builder/Vhdl suggestion
Hi..
i have daughtercard tvp5146, its output is 8bit in YCbCr 4:2:2 formate. i want black & white image at VGA output, thats why i have to zero the Cb and Cr part in YCbCr. i want only Y component out of YCbCr.
further i want to enhance this Y component to 8bit insted of 4bit.
How can i acheive this?
any good suggestion will be appreciated.
Thank you.
Rizwan
just append 4 '0's on the LSBs of the Y value.
Hi Tricky!
i have read in AN:427 that the format of YCbCr is
Y Cb Y Cr Y Cb Y Cr.
Further i want to enhance 4bit of Y to 8bit that.....
can you help me, please!
Thank you
Rizwan
Like I said, if Y is only 4 bits, you can make it 4 bits by appending 4 zeros to it. It will not enhance it in any way unless you do some digital processing.
thanks Tricky!
will you please guide me what type of digital processing is required ?
in other words what i have to do to enhance Y, such that i have 8bit Y data?
Best
Rizwan
Unless you add some filters to do some effects, you cant do allot to enhance Y because you've already thrown away half the data to make it only 4 bits. Appending zeros just puts it in the rage 0 to 255.
You could do some bilinear interpolation if you doubled the image size.
thanks Tricky!
i send you the file (ALT_ATLANTIC_SINK) that is having real time video in YCbCr format from the video daughter-card tvp5146, after this file i want only Y component.
please help me by code that i can put infront of ALT_ATLANTIC_SINK and having only Y component.
this Y component i want to input at VGA port to get Black & white image.
ALT_ATLANTIC_SINK is given by :
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.numeric_std.ALL;
USE STD.textio.ALL;
USE work.ALT_CUSP_PACKAGE.ALL;
ENTITY ALT_ATLANTIC_SINK IS
GENERIC (
NAME : STRING := "";
SIMULATION : INTEGER := SIMULATION_OFF;
OPTIMIZED : INTEGER := OPTIMIZED_ON;
MANUFACTURER : INTEGER := MANUFACTURER_ALTERA;
FAMILY : INTEGER := FAMILY_STRATIX;
INIT_FILE : STRING := "UNUSED";
WIDTH : INTEGER := 16;
PAGE_SIZE : INTEGER := 1;
ADDRESS_WIDTH : INTEGER := 8; -- CEIL(LOG2(PAGE_SIZE))
MEM_WIDTH : INTEGER := 8; -- CEIL(LOG2(PAGES*PAGE_SIZE)
END_PACKET_USED: INTEGER := 0;
PAGES : INTEGER := 0; -- unused
LOG2_PAGES : INTEGER := 0; -- unused
WRITE_PORTS : INTEGER := 0; -- unused
FULL_AT_START : INTEGER := 0;
LATENCY : INTEGER := 1; -- must be 1
READY_LATENCY : INTEGER := 2
PORT (
clock : IN STD_LOGIC;
reset : IN STD_LOGIC;
----------------- CUSP SIDE SIGNALS
ena : IN STD_LOGIC := '1';
addr : IN STD_LOGIC_VECTOR( ADDRESS_WIDTH-1 DOWNTO 0) := (others=>'0');
rdata : OUT STD_LOGIC_VECTOR( WIDTH-1 DOWNTO 0);
takeb : IN STD_LOGIC := '0'; -- take a page - block if not there
takeb_en : IN STD_LOGIC := '0'; --
takenb : IN STD_LOGIC := '0'; -- take a page - do not worry
takenb_en : IN STD_LOGIC := '0'; --
wdata : IN STD_LOGIC_VECTOR( WIDTH-1 DOWNTO 0) := (others=>'0'); -- Unused
wdata_en : IN STD_LOGIC := '0';
page_to_take : OUT STD_LOGIC; -- a page is ready to take
returnnb : IN STD_LOGIC := '0'; -- give a page
returnnb_en : IN STD_LOGIC := '0'; --
eop : OUT STD_LOGIC;
stall : OUT STD_LOGIC;
----------------- ATLANTIC SIDE SIGNALS
-- atlantic signals
ready : OUT STD_LOGIC;
valid : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR(WIDTH-1 DOWNTO 0) := (others=>'0');
startofpacket: IN STD_LOGIC := '0';
endofpacket : IN STD_LOGIC := '0'
END;
ARCHITECTURE rtl OF ALT_ATLANTIC_SINK IS
-- It takes 2 cycles for ready to react to valid, so we need buffering for
-- that as well as for READY_LATENCY (the time taken for valid to go low
-- after ready goes low)
CONSTANT DEPTH : INTEGER := READY_LATENCY + 2;
SIGNAL skid_full : STD_LOGIC_VECTOR(DEPTH-1 DOWNTO 0);
SIGNAL skid_data : STD_LOGIC_VECTOR((WIDTH * DEPTH)-1 DOWNTO 0);
SIGNAL skid_eop : STD_LOGIC_VECTOR(DEPTH-1 DOWNTO 0);
SIGNAL take : STD_LOGIC;
SIGNAL near_empty : STD_LOGIC;
SIGNAL empty : STD_LOGIC;
SIGNAL avail : STD_LOGIC;
SIGNAL skid_full2 : STD_LOGIC_VECTOR(DEPTH+1 DOWNTO 0);
SIGNAL skid_load : STD_LOGIC_VECTOR(DEPTH-1 DOWNTO 0);
BEGIN
-- The FU only ever drives takeb or takenb to get data out
take <= ((takeb AND takeb_en) OR (takenb AND takenb_en)) AND ena;
near_empty <= NOT skid_full(1);
empty <= NOT skid_full(0);
avail <= skid_full(0);
-- Stall the machine if there isn't any data
page_to_take <= avail;
stall <= (takeb AND takeb_en) AND NOT avail;
-- Latch the output data when requested. The cusp internals expect that
-- data will be maintained until it is replaced.
PROCESS(clock, reset)
BEGIN
IF reset = '1' THEN
rdata <= (others=>'0');
ELSIF clock'EVENT AND clock = '1' THEN
IF (avail AND take) = '1' THEN
rdata <= skid_data(WIDTH-1 DOWNTO 0);
END IF;
END IF;
END PROCESS;
-- Work out whether we're ready or not...
-- We're ready if there will be two spaces available on the next clock
BEGIN
IF reset = '1' THEN
ready <= '0';
ready <= (take AND near_empty) OR empty;
END IF;
END PROCESS;
check_depth : IF DEPTH < 2 GENERATE
ASSERT FALSE REPORT "DEPTH must be at least 2" SEVERITY ERROR;
END GENERATE;
skid_full2 <= ( '0' & skid_full & '1' );
-- Copy the input data when it is presented
gen_skid : FOR I IN 0 TO DEPTH-1 GENERATE
skid_load(I) <= ( ((NOT take) AND (NOT skid_full(I)) AND skid_full2(I)) OR
(take AND skid_full(I) AND (NOT skid_full2(I+2))) );
BEGIN
IF reset = '1' THEN
skid_full(I) <= '0';
skid_data(((I+1)*WIDTH-1) DOWNTO (I*WIDTH)) <= (others => '0');
IF (valid AND skid_load(I)) = '1' THEN
-- Load this entry of the FIFO
skid_full(I) <= '1';
skid_data(((I+1)*WIDTH-1) DOWNTO (I*WIDTH)) <= data;
ELSIF take = '1' AND I < DEPTH-1 THEN
-- If user has taken data then shift the FIFO
skid_full(I) <= skid_full(I+1);
skid_data((I+1)*WIDTH-1 DOWNTO I*WIDTH) <= skid_data((I+2)*WIDTH-1 DOWNTO (I+1)*WIDTH);
ELSIF take = '1' AND I = DEPTH-1 THEN
END IF;
END IF;
END PROCESS;
END GENERATE;
no_eop_generate: IF END_PACKET_USED = 0 GENERATE
eop <= '0';
END GENERATE;
eop_generate: IF END_PACKET_USED = 1 GENERATE
gen_eopskid : FOR I IN 0 TO DEPTH-1 GENERATE
BEGIN
IF reset = '1' THEN
skid_eop(I) <= '0';
skid_eop(I) <= endofpacket;
skid_eop(I) <= skid_data(I+1);
END IF;
END IF;
END PROCESS;
END GENERATE;
BEGIN
IF reset = '1' THEN
eop <= '0';
eop <= skid_eop(0);
END IF;
END IF;
END PROCESS;
END GENERATE;
END ;
Thank You
Rizwan
