FPGA Intellectual Property
6673 Discussions
Default Parallel Flash Loader isn't working
Gyud0
Hey,
I have a problem with Cyclone 3 device. The default Parallel Flash Loader (PFL) isn't working. I need a PFL for Active-Parallel configuration.
I noticed that there is a PFL IP by Altera but It mentioned that it supports in Passive-Serial or Fast-Passive-Parallel (Page 8) :
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Do you know about an IP for Active-Parallel configuration?
Thank you very much
NurAiman_M_Intel
Thank you for contacting Intel community.
As mention in the PFL userguide, PFL IP is only for  Passive-Serial or Fast-Passive-Parallel.
Kindly refer below for Active-parallel:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/cfg-index/cfg-ap.html
C3 handbook:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc3/cyclone3_handbook.pdf
Let me know if you need further information.
Aiman
Gyud0
hey,
In the link about the Active-parallel, the PFL IP is mentioned (AN 478). So the PFL IP does support the Active-Parallel or I should do a state machine by myself to configure the flash?
thanks
NurAiman_M_Intel
Apologize for the misunderstanding.
PFL IP do support Active parallel but only applicable to Cyclone 3 and 4 only. Active parallel supported common flash interface(CFI) parallel flash memory. Hence you may refer to AN478 for further information.
Thank you.
Aiman
