FPGA Intellectual Property
Delay for video IPs
I've seen that there's an ip to delay (to a max of 16 clock cycles) signals from avalon-ST. Unfortunatly, it does not support backpressure, so I suppose I can't use that to delay signal from streaming-video packet.
I tryed to write a custom blok to delay my signals, but it does not seem to wok. Well, sop, eop etc seems to work properly, but i see something like a vertical square pulse in the middle of the screen.
I only suppose that data_valid is not regular or has the same clock speed so it is not correcty stored in memory.
I'd like to know HOW can I properly add a delay to my system
Any hint would be appreciated.
If someone could find it useful, the code I wrote is
--- Quote Start ---
module shift_reg_ram_12# (parameter LENGTH=11)
input clk,
input reset,
input we,
input dout_ready,
input [15:0] din_data,
input din_valid,
input din_sop,
input din_eop,
//source
output din_ready ,
output reg [15:0] dout_data,
output reg dout_valid,
output reg dout_sop,
output reg dout_eop
reg [19:0] mem [15:0];
reg [4:0] addr;
always@(posedge clk) begin
if (we) mem[addr] <= {din_data,din_valid,din_sop,din_eop};
{dout_data,dout_valid,dout_sop,dout_eop}<= mem [addr];
end
always @ (posedge clk or posedge reset)
begin
if (reset)
addr <= 0;
else if (we) begin
if (addr<LENGTH)
addr <= addr + 1;
else
addr <=0;
end
end
assign din_ready=we;
endmodule
--- Quote End ---
Best regards
Phate
