FPGA Intellectual Property
6670 讨论
Difference between PCIE IP "Configuration Space Bypass" for Arria 10 and "TLP Bypass" for Stratix 10
lcy2000
初学者
1,392 次查看
Thank you for viewing this thread.
Currently I'm doing a tech selection for a custom PCIe switch. Both Arria 10 and Stratix 10 meets my requirements in terms of number of XCVRs, PCIe hard cores and logic resources.
But after reading "Avalon-ST PCIe IP" documents for both, I saw a little difference where Arria 10 claims that it features "Configuration Space Bypass" but Stratix 10 features "TLP Bypass".
So my question is that:
1. What's the difference between "Configuration Space Bypass" and "TLP Bypass"?
2. Do they provide equivalent capability to RX and TX all the valid TLP packets over the link?
Thank you very much
0 项奖励
1 解答
skbeh
员工
1,281 次查看
Hi Chenyang Li
I agreed that TLP Bypass(S10) is an acronym to configuration space bypass (A10).
It allows the implementation of advanced features such as:
- The upstream port or the downstream port of a switch.
- A custom implementation of a Transaction Layer to meet specific user requirements.
在原帖中查看解决方案
0 项奖励
3 回复数
skbeh
员工
1,334 次查看
Hi Chenyang Li
When the configuration space bypass mode is enabled, users coded their own sets of PCIe configuration registers (including the PCIe Express Capability and Secondary PCI Expess Extended Capability registers). It drives TLPs to the custom Configuration Space.
The IP will bypass the Transaction Layer Configuration Space registers included as
part of the Hard IP, allowing users to substitute a custom Configuration Space implemented in soft logic.
In TLP Bypass mode, all the TLP including the configuration TLP will be exposed to user logic through avst interface, customer can implement the user logics.
Both can pass all well‑formed TLPs to the Application Layer using the Avalon-ST RX interface.
0 项奖励
lcy2000
初学者
1,292 次查看
Thank you for answering my thread @skbeh.
I'm a little confused. So is there any limitation regarding PCIe for Arria 10 than Stratix 10?
As I see, it seems like TLP Bypass is an acronym to configuration space bypass.
Thank you very much.
0 项奖励
skbeh
员工
1,282 次查看
Hi Chenyang Li
0 项奖励
回复
