FPGA Intellectual Property
6670 Discussions
Dynamic Partial Reconfiguration on Stratix V
Hello everyone,
I want to dynamic reconfigure a partition of my design.
I have followed these steps so far:
a) make a revision of my project and assign the different personas for each revision.
b) make a region and enable the partial reconfiguration option from Logiclock Region window
c) make a partition for my re-configurable part and enable the multiple personas for this region
d) instantiate IP Partial Reconfiguration as internal host.
I don't know what to do next! Please could anyone provide some instructions for the DPR IP used as internal host?
Thanks in advance.
Hi Onoufrios,
did you already managed to convert .msf abd .sof to the partial rbf files?
This is how i do within a POST_FLOW_SCRIPT_FILE:
set path "output_files" set binaries "${path}/rbf" file mkdir ${binaries} set start_point x40y2 run_cmd "quartus_cpf -p $path/${revision}.${start_point}.msf $path/${revision}.sof $path/${revision}.${start_point}.pmsf" set options "" # lappend options "-o use_scrub=on" # lappend options "-o enhanced_bitstream_compression=on" # lappend options "-o bitstream_decompression_during_pr=on" set target_file "$binaries/${revision}.${start_point}.rbf" run_cmd "quartus_cpf -c $path/${revision}.${start_point}.pmsf ${target_file}"
The PR IP has two Registers, PR_CSR and PR_DATA.
[LIST]
set PR_CSR to 0x1 (start single clock PR)
[/LIST]
[LIST]
copy partial rbf to if->PR_DATA register
[/LIST]
[LIST]
check PR_CSR for status
[/LIST]
I guess you know this document already:
https://www.altera.com/en_us/pdfs/literature/ug/ug-partrecon.pdf
Additionally you need at least for CycloneV an extra PR license and you have to enable PR in quartus.ini. Don't know about StratixV.
--- Quote Start ---
Hi Onoufrios,
set path "output_files" set binaries "${path}/rbf" file mkdir ${binaries} set start_point x40y2 run_cmd "quartus_cpf -p $path/${revision}.${start_point}.msf $path/${revision}.sof $path/${revision}.${start_point}.pmsf" set options ""# lappend options "-o use_scrub=on"# lappend options "-o enhanced_bitstream_compression=on"# lappend options "-o bitstream_decompression_during_pr=on" set target_file "$binaries/${revision}.${start_point}.rbf" run_cmd "quartus_cpf -c $path/${revision}.${start_point}.pmsf ${target_file}"
  • set PR_CSR to 0x1 (start single clock PR)
  • copy partial rbf to if->PR_DATA register
  • check PR_CSR for status
--- Quote End ---
Thanks for your answer.
I am aware of this document you referred. I have the extra license for Stratix V for partial reconfiguration.
No, I haven't yet extracted the .sof/.msf/.rbf files yet because I first need to understand how to interact with the PR IP.
From your answer I understood that I need to make a ROM to store the rbf file (inside the FPGA) and a parser to feed the the PR IP along with the PR_CSR register (timings are depicted in the doc above).
An another question I have is: should I create a wrapper entity that will freeze all internal/external signals around my re-configurable entity? I only use one persona.
Someone needs to write the partial rbf to the IP, this could be a Nios or HPS System, or a simple statemachine from internal/external ROM.
As the StratixV has up to 2640 M20k Blocks you may be able to store one small PR partition :-).
A freeze wrapper would be a good design, but just for bench testing it works also without.
Thanks for your info, unfortunately I stuck again.
I tried today to convert the .rbf file to hexout memory file, in order to store it in a memory(ROM) and I could not find the way.
Do you know how to convert it?
I would prefer a mif file, the format is very easy.
A simple Matlab example is shown here, this could be easily ported to C, tcl, ...
http://www.alteraforum.com/forum/showthread.php?t=27934
You can also use srec_cat from the srecord Tools:
srec_cat dummy.rbf -binary -o dummy.mif -Memory_Initialization_File
I don't know if Altera provides a Tool for this simple task. I would use a small tcl loop, which can be easily started automatically during the build.
--- Quote Start ---
--- Quote End ---
I have a Stratix V GX Transceiver Development Kit. This board has a MAX CPLD device to configure the FPGA from a flash memory. As far I know the PFL (Parallel Flash Loader) IP does not support .rbf files. Do you know how can I implement the DPR from the flash memory? Any ideas?
Thanks a lot for you help.
Onoufrios
Hi Onoufrios,
sorry, i do not use Stratix. Can't you use a Nios as internal host and just copy the Data from the Flash?
--- Quote Start ---
Hi Onoufrios,
--- Quote End ---
Thanks for your feedback.
From the design's requirements I cannot use the internal host feature in the DPR IP. The device should be reconfigured from the IO Reconfiguration Pins. For any further suggestion please answer to my post.
Onoufrios
