FPGA Intellectual Property
6670 Discussions
EMIF Toolkit Traffic Generators in Arria 10 GX
Do I need to instantiate traffic generators separately after I set the "Use Configurable Avalon Traffic Generator 2.0" in the Diagnostic tab? If yes! where do I get these from?
I simply cannot figure this out from any of the Altera documentation. I am using Quartus Prime 16.1.
Thank you.
Sanjay
The traffic generator is included if you enable the option to include it when you generate the example design from the EMIF parameter editor. The EMIF toolkit will use it if you enable the option you mention. You can also manually add the traffic generator to a design as an IP in Qsys.
Steve
Thank you Steve,
Where can I find the IP? The generator IP used in the example design don't show up in the catalog.
Sanjay
Sorry, I thought it was a separate IP in Qsys but it's not. You enable it when you add the EMIF to a design. See this online training: https://www.altera.com/support/training/course.html?coursecode=omem1122
Steve
