I am trying to generate a DDR4 controller for Agilex 5 E-series, but all I seem to get is an empty box.
The generated verilog files look like this
[max@parma Workarea]$ cat quartus_dummy/ddr4/ddr4_inst.v
ddr4 u0 (
ddr4_bb.v ddr4.cmp ddr4.html ddr4_inst.vhd ddr4.qgsynthc ddr4.sopcinfo synth/
ddr4.bsf ddr4_generation.rpt ddr4_inst.v ddr4.ppf ddr4.qip ddr4.xml
[max@parma Workarea]$ cat quartus_dummy/ddr4/synth/ddr4.v
// ddr4.v
// Generated using ACDS version 24.1 115
`timescale 1 ps / 1 ps
module ddr4 (
ddr4_emif_ph2_mem_device_ddr4_220_gvofvjq emif_ph2_mem_device_ddr4_0 (
endmodule
Any idea what am I doing wrong?
Some questions about your issue:
1. Could you please share the ddr4_generation.rpt file?
2. Which Agilex 5 E device was used for the generation?
3. What kind of license files is used for Quartus?
Aaron
The generation report says
Info: Generated by version: 24.1 build 115
Info: Starting: Create block symbol file (.bsf)
Info: qsys-generate /home/max/Workarea/quartus_dummy/ddr4.ip --block-symbol-file --output-directory=/home/max/Workarea/quartus_dummy/ddr4 --family="Agilex 5" --part=A5ED065BB32AE6SR0
Info: Finished: Create block symbol file (.bsf)
Info:
Info: Starting: Create HDL design files for synthesis
Info: qsys-generate /home/max/Workarea/quartus_dummy/ddr4.ip --synthesis=VERILOG --output-directory=/home/max/Workarea/quartus_dummy/ddr4 --family="Agilex 5" --part=A5ED065BB32AE6SR0
Info: ddr4: "Transforming system: ddr4"
Info: ddr4: "Naming system components in system: ddr4"
Info: ddr4: "Processing generation queue"
Info: ddr4: "Generating: ddr4"
Info: ddr4: "Generating: ddr4_emif_ph2_mem_device_ddr4_220_gvofvjq"
Info: ddr4: Done "ddr4" with 2 modules, 1 files
Info: Finished: Create HDL design files for synthesis
Info: Starting: Generate IP Core Documentation
Info: No documentation filesets were found for components in ddr4. No files generated.
Info: Finished: Generate IP Core Documentation
I am targeting Agilex 5: A5ED065BB32AE6SR0
I have installed the Agilex 5 no cost license (but I have not been able to complete the generation of the programming file of the NIOS-V example I've found, see here)
What do you have in the synth directory where you generated the IP? Also, have you tried generating an example design?
$ ll ddr4/synth/
total 4
-rw-rw-r--. 1 max max 182 Apr 8 23:05 ddr4.v
$ cat ddr4/synth/ddr4.v
// ddr4.v
module ddr4 (
endmodule
I haven't generated an example design containing a ddr controller. The only one I have found has no EMIF.
Could you recommend one?
The example design gives reasonable results, e.g.
$ cat ./emif_ph2_0_example_design/qii/ip/ed_synth/ed_synth_emif_ph2_0/synth/ed_synth_emif_ph2_0.v
// ed_synth_emif_ph2_0.v
module ed_synth_emif_ph2_0 (
input wire ref_clk_0, // ref_clk_0.clk
input wire core_init_n_0, // core_init_n_0.reset_n
input wire usr_async_clk_0, // usr_async_clk_0.clk
output wire usr_rst_n_0, // usr_rst_n_0.reset_n
input wire [29:0] s0_axi4_araddr, // s0_axi4.araddr
input wire [1:0] s0_axi4_arburst, // .arburst
input wire [6:0] s0_axi4_arid, // .arid
input wire [7:0] s0_axi4_arlen, // .arlen
input wire s0_axi4_arlock, // .arlock
input wire [3:0] s0_axi4_arqos, // .arqos
input wire [2:0] s0_axi4_arsize, // .arsize
input wire s0_axi4_arvalid, // .arvalid
input wire [3:0] s0_axi4_aruser, // .aruser
input wire [2:0] s0_axi4_arprot, // .arprot
input wire [29:0] s0_axi4_awaddr, // .awaddr
input wire [1:0] s0_axi4_awburst, // .awburst
input wire [6:0] s0_axi4_awid, // .awid
input wire [7:0] s0_axi4_awlen, // .awlen
input wire s0_axi4_awlock, // .awlock
input wire [3:0] s0_axi4_awqos, // .awqos
input wire [2:0] s0_axi4_awsize, // .awsize
input wire s0_axi4_awvalid, // .awvalid
input wire [3:0] s0_axi4_awuser, // .awuser
input wire [2:0] s0_axi4_awprot, // .awprot
input wire s0_axi4_bready, // .bready
input wire s0_axi4_rready, // .rready
input wire [255:0] s0_axi4_wdata, // .wdata
input wire [31:0] s0_axi4_wstrb, // .wstrb
input wire s0_axi4_wlast, // .wlast
input wire s0_axi4_wvalid, // .wvalid
input wire [63:0] s0_axi4_wuser, // .wuser
output wire [63:0] s0_axi4_ruser, // .ruser
output wire s0_axi4_arready, // .arready
output wire s0_axi4_awready, // .awready
output wire [6:0] s0_axi4_bid, // .bid
output wire [1:0] s0_axi4_bresp, // .bresp
output wire s0_axi4_bvalid, // .bvalid
output wire [255:0] s0_axi4_rdata, // .rdata
output wire [6:0] s0_axi4_rid, // .rid
output wire s0_axi4_rlast, // .rlast
output wire [1:0] s0_axi4_rresp, // .rresp
output wire s0_axi4_rvalid, // .rvalid
output wire s0_axi4_wready, // .wready
output wire mem_ck_t_0, // mem_0.mem_ck_t
output wire mem_ck_c_0, // .mem_ck_c
output wire mem_cke_0, // .mem_cke
output wire mem_odt_0, // .mem_odt
output wire mem_cs_n_0, // .mem_cs_n
output wire [16:0] mem_a_0, // .mem_a
output wire [1:0] mem_ba_0, // .mem_ba
output wire mem_bg_0, // .mem_bg
output wire mem_act_n_0, // .mem_act_n
output wire mem_par_0, // .mem_par
input wire mem_alert_n_0, // .mem_alert_n
output wire mem_reset_n_0, // .mem_reset_n
inout wire [15:0] mem_dq_0, // .mem_dq
inout wire [1:0] mem_dqs_t_0, // .mem_dqs_t
inout wire [1:0] mem_dqs_c_0, // .mem_dqs_c
input wire oct_rzqin_0, // oct_0.oct_rzqin
input wire s0_axi4lite_clk, // s0_axil_clk.clk
input wire s0_axi4lite_rst_n, // s0_axil_rst_n.reset_n
input wire [26:0] s0_axi4lite_awaddr, // s0_axil.awaddr
input wire s0_axi4lite_awvalid, // .awvalid
output wire s0_axi4lite_awready, // .awready
input wire [31:0] s0_axi4lite_wdata, // .wdata
input wire [3:0] s0_axi4lite_wstrb, // .wstrb
input wire s0_axi4lite_wvalid, // .wvalid
output wire s0_axi4lite_wready, // .wready
output wire [1:0] s0_axi4lite_bresp, // .bresp
output wire s0_axi4lite_bvalid, // .bvalid
input wire s0_axi4lite_bready, // .bready
input wire [26:0] s0_axi4lite_araddr, // .araddr
input wire s0_axi4lite_arvalid, // .arvalid
output wire s0_axi4lite_arready, // .arready
output wire [31:0] s0_axi4lite_rdata, // .rdata
output wire [1:0] s0_axi4lite_rresp, // .rresp
output wire s0_axi4lite_rvalid, // .rvalid
input wire s0_axi4lite_rready, // .rready
input wire [2:0] s0_axi4lite_awprot, // .awprot
input wire [2:0] s0_axi4lite_arprot // .arprot
ed_synth_emif_ph2_0_emif_ph2_610_ftp76oi emif_ph2_inst (
.ref_clk_0 (ref_clk_0), // input, width = 1, ref_clk_0.clk
.core_init_n_0 (core_init_n_0), // input, width = 1, core_init_n_0.reset_n
.usr_async_clk_0 (usr_async_clk_0), // input, width = 1, usr_async_clk_0.clk
.usr_rst_n_0 (usr_rst_n_0), // output, width = 1, usr_rst_n_0.reset_n
.s0_axi4_araddr (s0_axi4_araddr), // input, width = 30, s0_axi4.araddr
.s0_axi4_arburst (s0_axi4_arburst), // input, width = 2, .arburst
.s0_axi4_arid (s0_axi4_arid), // input, width = 7, .arid
.s0_axi4_arlen (s0_axi4_arlen), // input, width = 8, .arlen
.s0_axi4_arlock (s0_axi4_arlock), // input, width = 1, .arlock
.s0_axi4_arqos (s0_axi4_arqos), // input, width = 4, .arqos
.s0_axi4_arsize (s0_axi4_arsize), // input, width = 3, .arsize
.s0_axi4_arvalid (s0_axi4_arvalid), // input, width = 1, .arvalid
.s0_axi4_aruser (s0_axi4_aruser), // input, width = 4, .aruser
.s0_axi4_arprot (s0_axi4_arprot), // input, width = 3, .arprot
.s0_axi4_awaddr (s0_axi4_awaddr), // input, width = 30, .awaddr
.s0_axi4_awburst (s0_axi4_awburst), // input, width = 2, .awburst
.s0_axi4_awid (s0_axi4_awid), // input, width = 7, .awid
.s0_axi4_awlen (s0_axi4_awlen), // input, width = 8, .awlen
.s0_axi4_awlock (s0_axi4_awlock), // input, width = 1, .awlock
.s0_axi4_awqos (s0_axi4_awqos), // input, width = 4, .awqos
.s0_axi4_awsize (s0_axi4_awsize), // input, width = 3, .awsize
.s0_axi4_awvalid (s0_axi4_awvalid), // input, width = 1, .awvalid
.s0_axi4_awuser (s0_axi4_awuser), // input, width = 4, .awuser
.s0_axi4_awprot (s0_axi4_awprot), // input, width = 3, .awprot
.s0_axi4_bready (s0_axi4_bready), // input, width = 1, .bready
.s0_axi4_rready (s0_axi4_rready), // input, width = 1, .rready
.s0_axi4_wdata (s0_axi4_wdata), // input, width = 256, .wdata
.s0_axi4_wstrb (s0_axi4_wstrb), // input, width = 32, .wstrb
.s0_axi4_wlast (s0_axi4_wlast), // input, width = 1, .wlast
.s0_axi4_wvalid (s0_axi4_wvalid), // input, width = 1, .wvalid
.s0_axi4_wuser (s0_axi4_wuser), // input, width = 64, .wuser
.s0_axi4_ruser (s0_axi4_ruser), // output, width = 64, .ruser
.s0_axi4_arready (s0_axi4_arready), // output, width = 1, .arready
.s0_axi4_awready (s0_axi4_awready), // output, width = 1, .awready
.s0_axi4_bid (s0_axi4_bid), // output, width = 7, .bid
.s0_axi4_bresp (s0_axi4_bresp), // output, width = 2, .bresp
.s0_axi4_bvalid (s0_axi4_bvalid), // output, width = 1, .bvalid
.s0_axi4_rdata (s0_axi4_rdata), // output, width = 256, .rdata
.s0_axi4_rid (s0_axi4_rid), // output, width = 7, .rid
.s0_axi4_rlast (s0_axi4_rlast), // output, width = 1, .rlast
.s0_axi4_rresp (s0_axi4_rresp), // output, width = 2, .rresp
.s0_axi4_rvalid (s0_axi4_rvalid), // output, width = 1, .rvalid
.s0_axi4_wready (s0_axi4_wready), // output, width = 1, .wready
.mem_ck_t_0 (mem_ck_t_0), // output, width = 1, mem_0.mem_ck_t
.mem_ck_c_0 (mem_ck_c_0), // output, width = 1, .mem_ck_c
.mem_cke_0 (mem_cke_0), // output, width = 1, .mem_cke
.mem_odt_0 (mem_odt_0), // output, width = 1, .mem_odt
.mem_cs_n_0 (mem_cs_n_0), // output, width = 1, .mem_cs_n
.mem_a_0 (mem_a_0), // output, width = 17, .mem_a
.mem_ba_0 (mem_ba_0), // output, width = 2, .mem_ba
.mem_bg_0 (mem_bg_0), // output, width = 1, .mem_bg
.mem_act_n_0 (mem_act_n_0), // output, width = 1, .mem_act_n
.mem_par_0 (mem_par_0), // output, width = 1, .mem_par
.mem_alert_n_0 (mem_alert_n_0), // input, width = 1, .mem_alert_n
.mem_reset_n_0 (mem_reset_n_0), // output, width = 1, .mem_reset_n
.mem_dq_0 (mem_dq_0), // inout, width = 16, .mem_dq
.mem_dqs_t_0 (mem_dqs_t_0), // inout, width = 2, .mem_dqs_t
.mem_dqs_c_0 (mem_dqs_c_0), // inout, width = 2, .mem_dqs_c
.oct_rzqin_0 (oct_rzqin_0), // input, width = 1, oct_0.oct_rzqin
.s0_axi4lite_clk (s0_axi4lite_clk), // input, width = 1, s0_axil_clk.clk
.s0_axi4lite_rst_n (s0_axi4lite_rst_n), // input, width = 1, s0_axil_rst_n.reset_n
.s0_axi4lite_awaddr (s0_axi4lite_awaddr), // input, width = 27, s0_axil.awaddr
.s0_axi4lite_awvalid (s0_axi4lite_awvalid), // input, width = 1, .awvalid
.s0_axi4lite_awready (s0_axi4lite_awready), // output, width = 1, .awready
.s0_axi4lite_wdata (s0_axi4lite_wdata), // input, width = 32, .wdata
.s0_axi4lite_wstrb (s0_axi4lite_wstrb), // input, width = 4, .wstrb
.s0_axi4lite_wvalid (s0_axi4lite_wvalid), // input, width = 1, .wvalid
.s0_axi4lite_wready (s0_axi4lite_wready), // output, width = 1, .wready
.s0_axi4lite_bresp (s0_axi4lite_bresp), // output, width = 2, .bresp
.s0_axi4lite_bvalid (s0_axi4lite_bvalid), // output, width = 1, .bvalid
.s0_axi4lite_bready (s0_axi4lite_bready), // input, width = 1, .bready
.s0_axi4lite_araddr (s0_axi4lite_araddr), // input, width = 27, .araddr
.s0_axi4lite_arvalid (s0_axi4lite_arvalid), // input, width = 1, .arvalid
.s0_axi4lite_arready (s0_axi4lite_arready), // output, width = 1, .arready
.s0_axi4lite_rdata (s0_axi4lite_rdata), // output, width = 32, .rdata
.s0_axi4lite_rresp (s0_axi4lite_rresp), // output, width = 2, .rresp
.s0_axi4lite_rvalid (s0_axi4lite_rvalid), // output, width = 1, .rvalid
.s0_axi4lite_rready (s0_axi4lite_rready), // input, width = 1, .rready
.s0_axi4lite_awprot (s0_axi4lite_awprot), // input, width = 3, .awprot
.s0_axi4lite_arprot (s0_axi4lite_arprot) // input, width = 3, .arprot
endmodule
I generated the ddr4 ip and its example design for device A5ED065BB32AE6SR0 with Agilex 5 E no-cost license and found no issue.
Please make sure the no-cost license had been acquired successfully. For Quartus Linux version you may need to set the proxy server for it and then apply the no-cost license.
Aaron
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
