FPGA Intellectual Property
EMIF on Agilex 5
suppamax
I am trying to generate a DDR4 controller for Agilex 5 E-series, but all I seem to get is an empty box.
The generated verilog files look like this
[max@parma Workarea]$ cat quartus_dummy/ddr4/ddr4_inst.v
	ddr4 u0 (
ddr4_bb.v            ddr4.cmp             ddr4.html            ddr4_inst.vhd        ddr4.qgsynthc        ddr4.sopcinfo        synth/
ddr4.bsf             ddr4_generation.rpt  ddr4_inst.v          ddr4.ppf             ddr4.qip             ddr4.xml
[max@parma Workarea]$ cat quartus_dummy/ddr4/synth/ddr4.v
// ddr4.v
// Generated using ACDS version 24.1 115
`timescale 1 ps / 1 ps
module ddr4 (
	ddr4_emif_ph2_mem_device_ddr4_220_gvofvjq emif_ph2_mem_device_ddr4_0 (
endmodule
Any idea what am I doing wrong?
zhenruan
Some questions about your issue:
1. Could you please share the ddr4_generation.rpt file?
2. Which Agilex 5 E device was used for the generation?
3. What kind of license files is used for Quartus?
Aaron
suppamax
The generation report says
Info: Generated by version: 24.1 build 115
Info: Starting: Create block symbol file (.bsf)
Info: qsys-generate /home/max/Workarea/quartus_dummy/ddr4.ip --block-symbol-file --output-directory=/home/max/Workarea/quartus_dummy/ddr4 --family="Agilex 5" --part=A5ED065BB32AE6SR0
Info: Finished: Create block symbol file (.bsf)
Info:
Info: Starting: Create HDL design files for synthesis
Info: qsys-generate /home/max/Workarea/quartus_dummy/ddr4.ip --synthesis=VERILOG --output-directory=/home/max/Workarea/quartus_dummy/ddr4 --family="Agilex 5" --part=A5ED065BB32AE6SR0
Info: ddr4: "Transforming system: ddr4"
Info: ddr4: "Naming system components in system: ddr4"
Info: ddr4: "Processing generation queue"
Info: ddr4: "Generating: ddr4"
Info: ddr4: "Generating: ddr4_emif_ph2_mem_device_ddr4_220_gvofvjq"
Info: ddr4: Done "ddr4" with 2 modules, 1 files
Info: Finished: Create HDL design files for synthesis
Info: Starting: Generate IP Core Documentation
Info: No documentation filesets were found for components in ddr4. No files generated.
Info: Finished: Generate IP Core Documentation
I am targeting Agilex 5: A5ED065BB32AE6SR0
I have installed the Agilex 5 no cost license (but I have not been able to complete the generation of the programming file of the NIOS-V example I've found, see here)
sstrell
What do you have in the synth directory where you generated the IP?  Also, have you tried generating an example design?
suppamax
$ ll ddr4/synth/
total 4
-rw-rw-r--. 1 max max 182 Apr  8 23:05 ddr4.v
$ cat ddr4/synth/ddr4.v
// ddr4.v
module ddr4 (
endmodule
I haven't generated an example design containing a ddr controller. The only one I have found has no EMIF.
Could you recommend one?
sstrell
No I mean have you generated an example design from the EMIF IP parameter editor?
suppamax
The example design gives reasonable results, e.g.
$ cat ./emif_ph2_0_example_design/qii/ip/ed_synth/ed_synth_emif_ph2_0/synth/ed_synth_emif_ph2_0.v
// ed_synth_emif_ph2_0.v
module ed_synth_emif_ph2_0 (
		input  wire         ref_clk_0,           //       ref_clk_0.clk
		input  wire         core_init_n_0,       //   core_init_n_0.reset_n
		input  wire         usr_async_clk_0,     // usr_async_clk_0.clk
		output wire         usr_rst_n_0,         //     usr_rst_n_0.reset_n
		input  wire [29:0]  s0_axi4_araddr,      //         s0_axi4.araddr
		input  wire [1:0]   s0_axi4_arburst,     //                .arburst
		input  wire [6:0]   s0_axi4_arid,        //                .arid
		input  wire [7:0]   s0_axi4_arlen,       //                .arlen
		input  wire         s0_axi4_arlock,      //                .arlock
		input  wire [3:0]   s0_axi4_arqos,       //                .arqos
		input  wire [2:0]   s0_axi4_arsize,      //                .arsize
		input  wire         s0_axi4_arvalid,     //                .arvalid
		input  wire [3:0]   s0_axi4_aruser,      //                .aruser
		input  wire [2:0]   s0_axi4_arprot,      //                .arprot
		input  wire [29:0]  s0_axi4_awaddr,      //                .awaddr
		input  wire [1:0]   s0_axi4_awburst,     //                .awburst
		input  wire [6:0]   s0_axi4_awid,        //                .awid
		input  wire [7:0]   s0_axi4_awlen,       //                .awlen
		input  wire         s0_axi4_awlock,      //                .awlock
		input  wire [3:0]   s0_axi4_awqos,       //                .awqos
		input  wire [2:0]   s0_axi4_awsize,      //                .awsize
		input  wire         s0_axi4_awvalid,     //                .awvalid
		input  wire [3:0]   s0_axi4_awuser,      //                .awuser
		input  wire [2:0]   s0_axi4_awprot,      //                .awprot
		input  wire         s0_axi4_bready,      //                .bready
		input  wire         s0_axi4_rready,      //                .rready
		input  wire [255:0] s0_axi4_wdata,       //                .wdata
		input  wire [31:0]  s0_axi4_wstrb,       //                .wstrb
		input  wire         s0_axi4_wlast,       //                .wlast
		input  wire         s0_axi4_wvalid,      //                .wvalid
		input  wire [63:0]  s0_axi4_wuser,       //                .wuser
		output wire [63:0]  s0_axi4_ruser,       //                .ruser
		output wire         s0_axi4_arready,     //                .arready
		output wire         s0_axi4_awready,     //                .awready
		output wire [6:0]   s0_axi4_bid,         //                .bid
		output wire [1:0]   s0_axi4_bresp,       //                .bresp
		output wire         s0_axi4_bvalid,      //                .bvalid
		output wire [255:0] s0_axi4_rdata,       //                .rdata
		output wire [6:0]   s0_axi4_rid,         //                .rid
		output wire         s0_axi4_rlast,       //                .rlast
		output wire [1:0]   s0_axi4_rresp,       //                .rresp
		output wire         s0_axi4_rvalid,      //                .rvalid
		output wire         s0_axi4_wready,      //                .wready
		output wire         mem_ck_t_0,          //           mem_0.mem_ck_t
		output wire         mem_ck_c_0,          //                .mem_ck_c
		output wire         mem_cke_0,           //                .mem_cke
		output wire         mem_odt_0,           //                .mem_odt
		output wire         mem_cs_n_0,          //                .mem_cs_n
		output wire [16:0]  mem_a_0,             //                .mem_a
		output wire [1:0]   mem_ba_0,            //                .mem_ba
		output wire         mem_bg_0,            //                .mem_bg
		output wire         mem_act_n_0,         //                .mem_act_n
		output wire         mem_par_0,           //                .mem_par
		input  wire         mem_alert_n_0,       //                .mem_alert_n
		output wire         mem_reset_n_0,       //                .mem_reset_n
		inout  wire [15:0]  mem_dq_0,            //                .mem_dq
		inout  wire [1:0]   mem_dqs_t_0,         //                .mem_dqs_t
		inout  wire [1:0]   mem_dqs_c_0,         //                .mem_dqs_c
		input  wire         oct_rzqin_0,         //           oct_0.oct_rzqin
		input  wire         s0_axi4lite_clk,     //     s0_axil_clk.clk
		input  wire         s0_axi4lite_rst_n,   //   s0_axil_rst_n.reset_n
		input  wire [26:0]  s0_axi4lite_awaddr,  //         s0_axil.awaddr
		input  wire         s0_axi4lite_awvalid, //                .awvalid
		output wire         s0_axi4lite_awready, //                .awready
		input  wire [31:0]  s0_axi4lite_wdata,   //                .wdata
		input  wire [3:0]   s0_axi4lite_wstrb,   //                .wstrb
		input  wire         s0_axi4lite_wvalid,  //                .wvalid
		output wire         s0_axi4lite_wready,  //                .wready
		output wire [1:0]   s0_axi4lite_bresp,   //                .bresp
		output wire         s0_axi4lite_bvalid,  //                .bvalid
		input  wire         s0_axi4lite_bready,  //                .bready
		input  wire [26:0]  s0_axi4lite_araddr,  //                .araddr
		input  wire         s0_axi4lite_arvalid, //                .arvalid
		output wire         s0_axi4lite_arready, //                .arready
		output wire [31:0]  s0_axi4lite_rdata,   //                .rdata
		output wire [1:0]   s0_axi4lite_rresp,   //                .rresp
		output wire         s0_axi4lite_rvalid,  //                .rvalid
		input  wire         s0_axi4lite_rready,  //                .rready
		input  wire [2:0]   s0_axi4lite_awprot,  //                .awprot
		input  wire [2:0]   s0_axi4lite_arprot   //                .arprot
	ed_synth_emif_ph2_0_emif_ph2_610_ftp76oi emif_ph2_inst (
		.ref_clk_0           (ref_clk_0),           //   input,    width = 1,       ref_clk_0.clk
		.core_init_n_0       (core_init_n_0),       //   input,    width = 1,   core_init_n_0.reset_n
		.usr_async_clk_0     (usr_async_clk_0),     //   input,    width = 1, usr_async_clk_0.clk
		.usr_rst_n_0         (usr_rst_n_0),         //  output,    width = 1,     usr_rst_n_0.reset_n
		.s0_axi4_araddr      (s0_axi4_araddr),      //   input,   width = 30,         s0_axi4.araddr
		.s0_axi4_arburst     (s0_axi4_arburst),     //   input,    width = 2,                .arburst
		.s0_axi4_arid        (s0_axi4_arid),        //   input,    width = 7,                .arid
		.s0_axi4_arlen       (s0_axi4_arlen),       //   input,    width = 8,                .arlen
		.s0_axi4_arlock      (s0_axi4_arlock),      //   input,    width = 1,                .arlock
		.s0_axi4_arqos       (s0_axi4_arqos),       //   input,    width = 4,                .arqos
		.s0_axi4_arsize      (s0_axi4_arsize),      //   input,    width = 3,                .arsize
		.s0_axi4_arvalid     (s0_axi4_arvalid),     //   input,    width = 1,                .arvalid
		.s0_axi4_aruser      (s0_axi4_aruser),      //   input,    width = 4,                .aruser
		.s0_axi4_arprot      (s0_axi4_arprot),      //   input,    width = 3,                .arprot
		.s0_axi4_awaddr      (s0_axi4_awaddr),      //   input,   width = 30,                .awaddr
		.s0_axi4_awburst     (s0_axi4_awburst),     //   input,    width = 2,                .awburst
		.s0_axi4_awid        (s0_axi4_awid),        //   input,    width = 7,                .awid
		.s0_axi4_awlen       (s0_axi4_awlen),       //   input,    width = 8,                .awlen
		.s0_axi4_awlock      (s0_axi4_awlock),      //   input,    width = 1,                .awlock
		.s0_axi4_awqos       (s0_axi4_awqos),       //   input,    width = 4,                .awqos
		.s0_axi4_awsize      (s0_axi4_awsize),      //   input,    width = 3,                .awsize
		.s0_axi4_awvalid     (s0_axi4_awvalid),     //   input,    width = 1,                .awvalid
		.s0_axi4_awuser      (s0_axi4_awuser),      //   input,    width = 4,                .awuser
		.s0_axi4_awprot      (s0_axi4_awprot),      //   input,    width = 3,                .awprot
		.s0_axi4_bready      (s0_axi4_bready),      //   input,    width = 1,                .bready
		.s0_axi4_rready      (s0_axi4_rready),      //   input,    width = 1,                .rready
		.s0_axi4_wdata       (s0_axi4_wdata),       //   input,  width = 256,                .wdata
		.s0_axi4_wstrb       (s0_axi4_wstrb),       //   input,   width = 32,                .wstrb
		.s0_axi4_wlast       (s0_axi4_wlast),       //   input,    width = 1,                .wlast
		.s0_axi4_wvalid      (s0_axi4_wvalid),      //   input,    width = 1,                .wvalid
		.s0_axi4_wuser       (s0_axi4_wuser),       //   input,   width = 64,                .wuser
		.s0_axi4_ruser       (s0_axi4_ruser),       //  output,   width = 64,                .ruser
		.s0_axi4_arready     (s0_axi4_arready),     //  output,    width = 1,                .arready
		.s0_axi4_awready     (s0_axi4_awready),     //  output,    width = 1,                .awready
		.s0_axi4_bid         (s0_axi4_bid),         //  output,    width = 7,                .bid
		.s0_axi4_bresp       (s0_axi4_bresp),       //  output,    width = 2,                .bresp
		.s0_axi4_bvalid      (s0_axi4_bvalid),      //  output,    width = 1,                .bvalid
		.s0_axi4_rdata       (s0_axi4_rdata),       //  output,  width = 256,                .rdata
		.s0_axi4_rid         (s0_axi4_rid),         //  output,    width = 7,                .rid
		.s0_axi4_rlast       (s0_axi4_rlast),       //  output,    width = 1,                .rlast
		.s0_axi4_rresp       (s0_axi4_rresp),       //  output,    width = 2,                .rresp
		.s0_axi4_rvalid      (s0_axi4_rvalid),      //  output,    width = 1,                .rvalid
		.s0_axi4_wready      (s0_axi4_wready),      //  output,    width = 1,                .wready
		.mem_ck_t_0          (mem_ck_t_0),          //  output,    width = 1,           mem_0.mem_ck_t
		.mem_ck_c_0          (mem_ck_c_0),          //  output,    width = 1,                .mem_ck_c
		.mem_cke_0           (mem_cke_0),           //  output,    width = 1,                .mem_cke
		.mem_odt_0           (mem_odt_0),           //  output,    width = 1,                .mem_odt
		.mem_cs_n_0          (mem_cs_n_0),          //  output,    width = 1,                .mem_cs_n
		.mem_a_0             (mem_a_0),             //  output,   width = 17,                .mem_a
		.mem_ba_0            (mem_ba_0),            //  output,    width = 2,                .mem_ba
		.mem_bg_0            (mem_bg_0),            //  output,    width = 1,                .mem_bg
		.mem_act_n_0         (mem_act_n_0),         //  output,    width = 1,                .mem_act_n
		.mem_par_0           (mem_par_0),           //  output,    width = 1,                .mem_par
		.mem_alert_n_0       (mem_alert_n_0),       //   input,    width = 1,                .mem_alert_n
		.mem_reset_n_0       (mem_reset_n_0),       //  output,    width = 1,                .mem_reset_n
		.mem_dq_0            (mem_dq_0),            //   inout,   width = 16,                .mem_dq
		.mem_dqs_t_0         (mem_dqs_t_0),         //   inout,    width = 2,                .mem_dqs_t
		.mem_dqs_c_0         (mem_dqs_c_0),         //   inout,    width = 2,                .mem_dqs_c
		.oct_rzqin_0         (oct_rzqin_0),         //   input,    width = 1,           oct_0.oct_rzqin
		.s0_axi4lite_clk     (s0_axi4lite_clk),     //   input,    width = 1,     s0_axil_clk.clk
		.s0_axi4lite_rst_n   (s0_axi4lite_rst_n),   //   input,    width = 1,   s0_axil_rst_n.reset_n
		.s0_axi4lite_awaddr  (s0_axi4lite_awaddr),  //   input,   width = 27,         s0_axil.awaddr
		.s0_axi4lite_awvalid (s0_axi4lite_awvalid), //   input,    width = 1,                .awvalid
		.s0_axi4lite_awready (s0_axi4lite_awready), //  output,    width = 1,                .awready
		.s0_axi4lite_wdata   (s0_axi4lite_wdata),   //   input,   width = 32,                .wdata
		.s0_axi4lite_wstrb   (s0_axi4lite_wstrb),   //   input,    width = 4,                .wstrb
		.s0_axi4lite_wvalid  (s0_axi4lite_wvalid),  //   input,    width = 1,                .wvalid
		.s0_axi4lite_wready  (s0_axi4lite_wready),  //  output,    width = 1,                .wready
		.s0_axi4lite_bresp   (s0_axi4lite_bresp),   //  output,    width = 2,                .bresp
		.s0_axi4lite_bvalid  (s0_axi4lite_bvalid),  //  output,    width = 1,                .bvalid
		.s0_axi4lite_bready  (s0_axi4lite_bready),  //   input,    width = 1,                .bready
		.s0_axi4lite_araddr  (s0_axi4lite_araddr),  //   input,   width = 27,                .araddr
		.s0_axi4lite_arvalid (s0_axi4lite_arvalid), //   input,    width = 1,                .arvalid
		.s0_axi4lite_arready (s0_axi4lite_arready), //  output,    width = 1,                .arready
		.s0_axi4lite_rdata   (s0_axi4lite_rdata),   //  output,   width = 32,                .rdata
		.s0_axi4lite_rresp   (s0_axi4lite_rresp),   //  output,    width = 2,                .rresp
		.s0_axi4lite_rvalid  (s0_axi4lite_rvalid),  //  output,    width = 1,                .rvalid
		.s0_axi4lite_rready  (s0_axi4lite_rready),  //   input,    width = 1,                .rready
		.s0_axi4lite_awprot  (s0_axi4lite_awprot),  //   input,    width = 3,                .awprot
		.s0_axi4lite_arprot  (s0_axi4lite_arprot)   //   input,    width = 3,                .arprot
endmodule
zhenruan
I generated the ddr4 ip and its example design for device A5ED065BB32AE6SR0 with Agilex 5 E no-cost license and found no issue.
Please make sure the no-cost license had been acquired successfully. For Quartus Linux version you may need to set the proxy server for it and then apply the no-cost license.
Aaron
WZ2
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
