FPGA Intellectual Property
Errata for COTS IP
yolanda
I need to all of he latest errata for all of the COTS IP that we are using. Is the proper/best way to gather the latest Errata for the IP located by searching on the Knowledge Base webpage, is there a PDF that is updated regularly that I could reference for my documents?
SengKok_L_Intel
If you are using Intel FPGA IP, you can check the knowledge data case in the following link for all the known issues.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/kdb-filter.html
Regards -SK
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
