FPGA Intellectual Property
6670 Discussions
Error (14566): The Fitter cannot place for ethernet 10G IP
hi,
1. I generate one Low latency Ethernet 10G MAC IP with the mode "10GBASE-R Register Mode Example Design arria 10".
As the generated tx_serial_data/rx_serial_data pin in the IP's input/output is single-ended, I think I need to use a differential IO pin in my top design . so I insert one differential BUF for it before it is connected to the Low latency Ethernet 10G MAC IP core.
fbm_ibuf_multichan u_fbm_ibuf_multichan (
.dout ( rx_serial_data ), // dout.export
.pad_in ( rx_serial_data_p ), // pad_in.export
.pad_in_b ( rx_serial_data_n ) // pad_in_b.export
fbm_obuf_multichan u_fbm_obuf_multichan
//input
.pad_out_b ( tx_serial_data_n ),
.pad_out ( tx_serial_data_p ),
.din ( tx_serial_data )
then tx_serial_data/rx_serial_data is connected to the Low latency Ethernet 10G MAC IP core.
2. I am using DEVICE 10AX115U4F45I3SGE2
3. the pin assignments for tx_serial_data /rx_serial_data are: (BANK GXBL1E)
set_location_assignment PIN_AN42 -to tx_serial_data_p[0]
set_location_assignment PIN_AN38 -to rx_serial_data_p[0]
But I meet Error in the Fitter(as shown below)
So my question is:
1) why the pin of tx_serial_data/rx_serial_data in the generated Low latency Ethernet 10G MAC IP core is single-ended?
2) Is it correct to connect one differential BUF for it?
3) How to fix this error?
Error (175001): The Fitter cannot place 1 HSSI_PMA_TX_BUF.
Info (14596): Information about the failing component(s):
Info (175028): The HSSI_PMA_TX_BUF name(s): hft_ethernet_multichan:u_hft_ethernet_multichan|altera_eth_10g_mac_base_r_low_latency_wrap:packet_div_channels[0].i_u_altera_eth_10g_mac_base_r_low_latency_wrap|low_latency_baser:baser_inst|low_latency_baser_altera_xcvr_native_a10_161_dsfdwxi:xcvr_native_a10_0|twentynm_xcvr_native:g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_rev_20nm5es2:twentynm_xcvr_native_inst|twentynm_pma_rev_20nm5es2:inst_twentynm_pma|gen_twentynm_hssi_pma_tx_buf.inst_twentynm_hssi_pma_tx_buf
Error (16234): No legal location could be found out of 96 considered location(s). Reasons why each location could not be used are summarized below:
Error (175006): Could not find path between source pin and the HSSI_PMA_TX_BUF
Info (175026): Source: pin rx_serial_data_p[0]
Info (175015): The I/O pad rx_serial_data_p[0] is constrained to the location PIN_AN38 due to: User Location Constraints (PIN_AN38)
Info (14709): The constrained I/O pad is contained within this pin
Info (175021): The pin was placed in location pin containing PIN_AN38
Error (175022): The HSSI_PMA_TX_BUF could not be placed in any location to satisfy its connectivity requirements
Info (175029): 95 locations affected
Info (175029): HSSIPMATXBUF_1C0
Info (175029): HSSIPMATXBUF_1C1
Info (175029): HSSIPMATXBUF_1C2
Info (175029): HSSIPMATXBUF_1C3
Info (175029): HSSIPMATXBUF_1C4
Info (175029): HSSIPMATXBUF_1C5
Info (175029): HSSIPMATXBUF_1D0
Info (175029): HSSIPMATXBUF_1D1
Info (175029): HSSIPMATXBUF_1D2
Info (175029): HSSIPMATXBUF_1D3
Info (175029): HSSIPMATXBUF_1D4
Info (175029): HSSIPMATXBUF_1D5
Info (175029): and 83 more locations not displayed
Error (175003): The HSSI_PMA_TX_BUF location is occupied (1 location affected)
Info (175029): HSSIPMATXBUF_1E0. Already placed at this location: HSSI_PMA_TX_BUF tx_serial_data_p[0]~output_PMA_TX_BUF_FITTER_INSERTED
Error (15307): Cannot apply project assignments to the design due to illegal or conflicting assignments. Refer to the other messages for corrective action.
