FPGA Intellectual Property
6669 Discussions
Error when compiling simple video application
I try to compile a very simple system using two video Megacore functions and a Nios II
-test pattern generator directly connected to
- video output
during compilation I have got the following message
Error: Node instance "auto_inst" instantiates undefined entity "alt_vip_tpg_0_GN"
Attached is a document with screen shots showing SOPC architecture, toplevel bdf and error message
Thank for your help
Jacques
Config is :
Windows XP
Quartus 9.1
Stratix IV
Audio video Developmemnt kit Stratix IV GX Edtion
I get exactly the the same message. Perhaps you've already solved the problem.
Thanks in advace
Andreas Schwirzer
You need to manually add the VHDL file for your "alt_vip_tpg_0" block to your Quartus project. It can't find the entity.
Jake
Thank you for reply.
The problem occurred because of administration rights in windows 7. Running Quartus as administrator, without any changes to my project, there are no more errors.
Andreas
I wonder if any one can help me. I have the same problem as Ehrlich, however I have tried the suggestions here with no luck. Ehrlich, can you please share what you did to resolve this?
Thank you,
Harold
I forgot mention that the alt_vip_tpg_0_GN.vhd file generated from my project is 0KB in size. Could I be missing a licence or something? Thanks
make sure you run as administrator when using VIP Suite in Windows. the SOPC Builder system needs to be generated as administrator also
Thanks thepancake - that worked!
While it may not always be the case, we found the solution to errors such as these are to check the IP Cores that the file uses and install/reinstall using the Megawizard. Has worked nearly every time.
--- Quote Start ---
--- Quote End ---
Hi trennert,
I facing the same issue. Can you please mention in detail.
