FPGA Intellectual Property
6669 Discussions
FFT modelsim stand alone simulation
I new to Quartus II and ModelSim. I am trying to simulate the FFT MegaCore and I am getting a VHDL compile error. I have reviewed the documentation but I don't see what I am doing wrong. The documentation I am looking at is "Ch 6: Simulating Altera IP in Third-Party Simulation Tools page 6-11" The Q2 generated VHDL uses the lib/package "fft_lib.fft_pack_fft_90" I don't see how the package "fft_pack_fft_90" gets included into the vcom command. I do see a binary file called "fft_pack_fft_90.vhd" which Q2 generated.
vcom -work work -93 -explicit fft.vhd# Model Technology ModelSim SE-64 vcom 6.1a Compiler 2005.07 Jul 19 2005# -- Loading package standard# -- Loading package std_logic_1164# ** Error: (vcom-19) Failed to access library 'fft_lib' at "fft_lib".
Hi
You have to compile that generated .vhd into your library and set pathes that the library is known by modelsim.
I'm more used to the GUI way, so I describe this one (command line version should be similar, but you have to add pathes yourself...)
Start Modelsim
Library -> New library
[x] a new library and a logical mapping to it
Library name [fft_lib]
Library Physical name [fft_lib]
> OK
Compile > Compile...
Library [fft_lib]
Filename [./fft_pack_fft_90.vhd]
> Compile
Now you should see the fft_lib beside the other libraries and see the building blocks compiled into it. Open and build your simulation now.
Hope this helps,
Peter
