FPGA Intellectual Property
FIR I vs FIR II
I have used FIR I in a couple of projects (Quartus 9.1). I am considering upgrading to the latest Quartus and buying FIR II. In FIR I there is an "Edit Coefficients" button to open a configuration window where you can select the type of filter (e.g. Blackman) and enter the required frequency cut-off. This seems to have disappeared in FIR II? Are you expected to use another tool to generate the Coefficients?
I do not have MATLAB, but do have the Microchip dspWorks filter tool. Is this my best option going forward?
If this feature has ben removed wasn't this a step backwards?
