FPGA Intellectual Property
6670 Discussions
Does PCIe HD IP include the PHY IP Core? How to pin assignment for differential?
Hi all,
I have one starter Kit of Arria V. And I want to realize one application with <Avalon-MM Arria V hard HD IP for PCIe>.
My 2 questions:
1. Does <Avalon-MM Arria V hard HD IP for PCIe> include the PHY IP Core?
Need I add the additional PHY IP Core for <Avalon-MM Arria V hard HD IP for PCIe>?
2. In the top-level entity of PHY IP Core of PCIe, which signals are for differential couples? How should I do pin-assignment for the differential?
I cannot find the pair of +/- signals in the interface PHY IP Core of PCIe. It is confusion.
I wait your professional answer.
Thanks in advance.
--- Quote Start ---
--- Quote End ---
Yes, Avalon-MM Arria V hard HD IP for PCIe include the PHY IP Core, Refer page No:12 or Configurations session of below link.
https://www.altera.com/en_us/pdfs/literature/ug/ug_a5_pcie_avmm.pdf
--- Quote Start ---
--- Quote End ---
Check the development kit user guide for pin details or design example for more information.
Refer page No 37.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/rm_avgx_starter_board.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Anand Raj Shankar,
Thanks a lot.
And I've also found one example about Avalon-MM Arria V Hard IP for PCI Express on Arria V GX Starter Kit. The link is following:
http://www.alterawiki.com/uploads/2/2f/a5gx_gen2x4_14_0.zip
It will be helpful for my design. Thanks again.
Best regards
JiaShiqi
Hi, Anand Raj Shankar
It is very helpful to understand.
Thanks a lot.
