FPGA Intellectual Property
FIR IP
ElizabethJaison
I was simulating a 35 tap fractional filter operating at 150MHz clock implemented using intel FIR IP.
The input sampling rate is 150msps and output sampling rate is 100msps (interpolation factor:2, decimation factor:3).
So the ip gives 2 valid data output in 3 clock cycles as represented in case 1 in the attached excel sheet(refer SRC_DOWN23_FIR_IP_configurations and timing_diagram.xlsx)
But is there any chance of getting output data as represented in case2 in SRC_DOWN23_FIR_IP_configurations and timing_diagram.xlsx ?
Thanking you in advance.
Elizabeth
