FPGA Intellectual Property
FIR_LP Problem
I have a problem of gain with a fir_lp (value < expected value )!!!
config :
filtre_type : low pass
sample rate :10khz
cutoff freq :500hz
coeff : 15
input number system : unsigned binary
ast_sink_data :INPUT data width 16 bits ( data signal 50hz ampl : 2.5V --> 65535 )
ast_source_data :OUTPUT width 27 bits full resolution
when i calculate RMS (value < expected value) :
{ data in for RMS : lp_out(lp_out'high downto lp_out'high-15) }
thinks for help
Cutoff freq is 1/20 of sample frequency, it's impossible to design a good FIR filter with 15 or 30 taps. A first or second order IIR filter will perform much better in this case.
Thanks for replying,
Can i generate irr filter from megawizard or i should design it ?
There is no Altera IP for IIR filters as far as I know. MatLab or special filter tools can be used to calculate the difference equation coefficients.
ok thanks,
So it's impossible to use altera FIR compiler with Cutoff freq 1/20 of sample frequency even if i change coeff?
fir attenuation image (http://img3.imageshack.us/img3/4210/firlp.jpg)
in this image
udat : input signal 16hz (16 bits)
fir_lp : width 37 bits
coeff : 100
(i have always an attenuation even with others coeff)
we should start with specifications.
sampling rate:
pass band:
stop band:
in band ripple:
stop band attenuation:
then we can define how many taps you need, how many bits to use, etc.
