FPGA Intellectual Property
FIR filter
I'm using the FIR filter compiler of the megawizard to compile 2 bandpass filters. It all goes well 'till I use them in a toplevel. Somehow I can't seem to find my mistake.
The filters use each a different clock (60 MHz PLL clock and a 229 Hz clock) as sample frequencies.
When compiling I get warnings: "No clock transition on .... register" these registers are located in the encrypted files of the FIR Filters.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; entity Toplevel is port( SYSTEM_CLOCK : in std_logic; --System clock is 100MHz reset : in std_logic; indata : in std_logic_vector(7 downto 0); outdataV : out std_logic_vector(7 downto 0); outdataH : out std_logic_vector(7 downto 0) ); end Toplevel; architecture behav of Toplevel is component VsyncFilter port( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; ast_sink_data : IN STD_LOGIC_VECTOR (7 DOWNTO 0); ast_sink_valid : IN STD_LOGIC; ast_source_ready : IN STD_LOGIC; ast_sink_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0); ast_source_data : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); ast_sink_ready : OUT STD_LOGIC; ast_source_valid : OUT STD_LOGIC; ast_source_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0) ); end component; component HsyncFilter port ( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; ast_sink_data : IN STD_LOGIC_VECTOR (7 DOWNTO 0); ast_sink_valid : IN STD_LOGIC; ast_source_ready : IN STD_LOGIC; ast_sink_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0); ast_source_data : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); ast_sink_ready : OUT STD_LOGIC; ast_source_valid : OUT STD_LOGIC; ast_source_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0) ); end component; component PLL port( areset : in std_logic; inclk0 : in std_logic; pllena : in std_logic; c0 : out std_logic; locked : out std_logic ); end component; signal one : std_logic := '1'; signal Clk : std_logic; -- clock 60 Mhz signal noerror : std_logic_vector(1 downto 0) := "00"; signal locked : std_logic; signal ctr : std_logic_vector(18 downto 0); signal Clk229 : std_logic; begin -- transform 60MHz clock to 229 Hz by adding a counter counter : process(Clk, reset) begin if reset = '1' then ctr <= (others => '0'); elsif rising_edge(Clk) then ctr <= ctr + 1; end if; end process counter; Clk229 <= ctr(18); Clk229out <= Clk229; U1 : VsyncFilter port map ( clk => Clk229, reset_n => NOT reset, ast_sink_data => indata, ast_sink_valid => one, ast_source_ready => one, ast_sink_error => noerror, ast_source_data => outdataV ); U2 : HsyncFilter port map ( clk => Clk, reset_n => NOT reset, ast_sink_data => indata, ast_sink_valid => one, ast_source_ready => one, ast_sink_error => noerror, ast_source_data => outdataH ); U3 : PLL port map ( areset => reset, inclk0 => SYSTEM_CLOCK, pllena => one, c0 => Clk, locked => locked ); end behav;
thanks in advance,
Steven
Have you connected system_clock!!!
what is driving clk?
edit:
sorry you have...
You must set one as '1' in the architecture as assignment:
begin
one <= '1';
because initialisation is ignored by synthesis tool except for memory at least
