FPGA Intellectual Property
6673 Discussions
Failed to transfer to modelsim
In the .mdl file,when I used the Testbench model to run modelsim, errers were found in modelsim:
# Reading D:/altera/71/modelsim_ae/tcl/vsim/pref.tcl
# source tb_mymodel.tcl
# Loading project DspBuilder
# vsim -quiet -t {1 ps} work.tb_mymodel_GN2124
# ** Error: Failure to obtain a VHDL simulation ******.
# Error loading design
# Unrecognized dataset prefix: sim
what's the matter?
Thanks!
Are you using the same version number for QuartusII and Modelsim?
Was the error line you stated
actually
# ** Error: Failure to obtain a VHDL simulation license?
Looks a bit similar too the normal modelsim failure if your license file is not setup properly.
Have a look here
http://www.altera.com/support/licensing/lic-index.html
For info on how to setup the license files and environment variables
I am sorry. Yes,the error is # ** Error: Failure to obtain a VHDL simulation license.
I used the same version number for QuartusII and Modelsim, and its license files and environment variables should be right , I used it before. I will check it too.
Thanks,I solved the problem. My license was incomplete, and I have updated it. Now it's OK.
