Are there any (free?) compact flash controllers available that use True Ide mode? Would be using it in MAX II and Cyclone III. Thanks.
I know that's on the website of opencores. I'm using it now; however, i have some problem............
I believe altera is providing a CF controller in True IDE mode for free along with the SOPC builder. I'm not sure, though, whether you are using SOPC Builder or not. But you can take a look at it and see if it helps. It's user guide can be found at http://www.altera.com/literature/hb/nios2/qts_qii55005.pdf
