FPGA Intellectual Property
6673 Discussions
Compact flash controller?
Are there any (free?) compact flash controllers available that use True Ide mode? Would be using it in MAX II and Cyclone III. Thanks.
I know that's on the website of opencores. I'm using it now; however, i have some problem............
I believe altera is providing a CF controller in True IDE mode for free along with the SOPC builder. I'm not sure, though, whether you are using SOPC Builder or not. But you can take a look at it and see if it helps. It's user guide can be found at http://www.altera.com/literature/hb/nios2/qts_qii55005.pdf
