FPGA Intellectual Property
6673 Discussions
Failure to configure S4GX device using MAXII with PFL
hi. im using the MAXII with PFL ip to configure S4GX device. the flash device is numonyx 256M flash.
i am able to program the flash & load a sof file using the JTAG if to the S4 but when i try usung configuration using the PFL - no success.
im using the FPP scheme - burst mode.
is there any importance to the option_BITS?? what is it?
are there any known issues with the quartus 9.1?
is there a ref design for the maxII using PFL?
i really need ur help..
thnx
you have to use the --optionbits --programmingmode and --pfl flags:
http://www.altera.com/support/kdb/solutions/rd08102010_306.html
i also think there were some issues with sof2flash in 9.1, you'll want to use 9.1sp1 or 9.1sp2. you should be able to find a solution that has the details
i have to state that im not usin NIOS..only MAXII with PFL
