FPGA Intellectual Property
6667 Discussions
GMII interfaec for GigaE in LLE + Native PHY IP.
ASey
Hello guys,
I want to configure GigE using LLE IP and native PHY on cyclone 10gx EVB. Gmii_rx_d [8] on the MAC side is connected to rx_parallel_data [8] on native PHY. However, gmii_rx_dv [1] does not know which signal from PHY should be connected.
Usually, the IP is the gmii interface in PHY, but the native PHY does not
I do not know if I made the wrong setting.
Please ask for help if you know.
One mere thing is gmii_tx_en.
Thank you.
ASey
In addition,
Development environment : Quartus 18.0 pro / LLE ip + Native PHY ip​ / qsys
​case : 10g interface [ parallel data & control ] <=>[gmii]
wire [7:0]                    xgmii_tx_control;
wire [63:0]                  xgmii_tx_data;
wire [71:0]     xgmii_tx;
wire [7:0]                    xgmii_rx_control;
wire [63:0]                  xgmii_rx_data;
wire [71:0]     xgmii_rx;
assign xgmii_tx_data = {
  xgmii_tx[70:63],
  xgmii_tx[61:54],
  xgmii_tx[52:45],
  xgmii_tx[43:36],
  xgmii_tx[34:27],
  xgmii_tx[25:18],
  xgmii_tx[16:9],
  xgmii_tx[7:0]
assign xgmii_tx_control = {
  xgmii_tx[71],
  xgmii_tx[62],
  xgmii_tx[53],
  xgmii_tx[44],
  xgmii_tx[35],
  xgmii_tx[26],
  xgmii_tx[17],
  xgmii_tx[8]
assign xgmii_rx = {
  xgmii_rx_control[7], xgmii_rx_data[63:56],
  xgmii_rx_control[6], xgmii_rx_data[55:48],
  xgmii_rx_control[5], xgmii_rx_data[47:40],
  xgmii_rx_control[4], xgmii_rx_data[39:32],
  xgmii_rx_control[3], xgmii_rx_data[31:24],
  xgmii_rx_control[2], xgmii_rx_data[23:16],
  xgmii_rx_control[1], xgmii_rx_data[15:8],
  xgmii_rx_control[0], xgmii_rx_data[7:0]};
if i had to make 1g.......​ when phy to mac (rx) , mac to phy (tx)
rx_gmii_d
rx_ gmii_dv
rx_gmii_err
tx_gmii_d
tx_gmii_en
tx_gmii_err
BoonT_Intel
For C10 GX LLE with NativePHY design. I will suggest you refer to the example design that describe in this user guide.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20162.pdf
This design demonstrate ethernet solution using LL10GbE with native PHY IP.
Hope this helps.
