FPGA Intellectual Property
6659 Discussions
HDL Import [state machine in VHDL]
Hi everyone,
I designed a state machine in VHDL and I would like to incorporate it to my Simulink + DSP Builder Model. I'm using HDL Import, however upon pressing Compile button I get the error message shown bellow. Same happens when I try to compile the whole Quartus project.
State machine VHDL is attached to this message.
I would appreciate any hints on how to solve this problem.
Oz
--- Quote Start ---
Generating Simulink model........
Info: *******************************************************************
Info: Running Quartus II 64-Bit Analysis & Synthesis
Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full
Version
Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Sat Mar 28 15:03:10 2015
Info: Command: quartus_map suballoc --source=../../suballoc/suballoc.vhd
--simgen
--simgen_parameter=SIMGEN_C_NETLIST=ON,SIMGEN_OPTIMIZATION=ALL,SIMGEN_PRESERVE_PORT_ORDER=ON
Info (20029): Only one processor detected - disabling parallel compilation
Info (12021): Found 2 design units, including 1 entities, in source file
/primjeri/suballoc/suballoc.vhd
Info (12022): Found design unit 1: suballoc-behavioral
Info (12023): Found entity 1: suballoc
Info (12127): Elaborating entity "suballoc" for the top level hierarchy
Info (281010): Generating sgate simulator netlist using Simgen
SIMGEN_PROGRESS Start of Model generation -- 0% complete
SIMGEN_PROGRESS Phase 1 : Internal Objects created -- 25% complete
SIMGEN_PROGRESS Phase 2 : Connections between internal objects
made -- 60% complete
SIMGEN_PROGRESS Phase 3 : Netlist generated -- 100% complete
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 5 to 5 assigned. CAUSE :
The port range was already assigned a value. The new value can not be
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 5 to 5 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 5 to 5 assigned.
CAUSE : The port range was already assigned a value. The new value can
not be reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 4 to 4 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 4 to 4 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 4 to 4 assigned.
not be reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 3 to 3 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 3 to 3 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 3 to 3 assigned.
not be reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 2 to 2 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 2 to 2 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 2 to 2 assigned.
not be reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 1 to 1 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 1 to 1 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 1 to 1 assigned.
not be reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|dataa already has one or more bits in the range 0 to 0 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|datab already has one or more bits in the range 0 to 0 assigned. CAUSE :
reassigned.
Error (281011): MGL_INTERNAL_ERROR: The source port simgen|mux21 inst nl|outputselect already has one or more bits in the range 0 to 0 assigned.
not be reassigned.
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 18 errors,
0 warnings
Error: Peak virtual memory: 519 megabytes
Error: Processing ended: Sat Mar 28 15:03:12 2015
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:02
Error: Quartus II Analysis & Synthesis was unsuccessful
--- Quote End ---
The source compiles OK with Quartus II 14.1
However the following code is a bit odd to read
process(clk_in, init_in, counter) begin if (rising_edge(clk_in) and init_in = '1') then if (counter = 63) then counter <= 0; -- resets counter when it reaches 320 else counter <= counter + 1; end if; elsif (rising_edge(clk_in) and init_in = '0') then counter <= 0; -- if "init_in" is set to 0, counter resets, as well as "start_tx_out" end if; end process;
and most would write it like this:
process(clk_in) begin if rising_edge(clk_in) then if (init_in = '1') then if (counter = 63) then counter <= 0; -- resets counter when it reaches 320 else counter <= counter + 1; end if; else counter <= 0; -- if "init_in" is set to 0, counter resets, as well as "start_tx_out" end if ; end if; end process;
Both ways seem to generate the same result, though.
Thank you for the comment and suggestions. The code looks much better.
I can actually compile original code in Quartus as well (no errors/warnings). The problem is importing this code into Simulink model with DSP Builder.
