FPGA Intellectual Property
6670 Discussions
Hi, I'm trying to make a delay instruction in verilog, I have an output (PWM) and I want to generate another output (PWM1) from PWM but with a delay: i tried this : assign #50 pwm1 = pwm; but it's not working best regards,
OABBA1
Vicky1
In verilog '#' is not synthesizable so delays are useful for behavioral simulation in testbenches not in design. If you want to create delays in design that you can achieve using Flip flops & buffers. Single D-Flipflop will generate single clock cycle delay & you can generate multiple clock delays using counter.
Vicky
OABBA1
thank you!
here it's my code :
module pwm_main (up, dn, pwm, pwm_inv, pwm1, pwm2, pwm3, pwm4);
input up, dn;            // PWM control buttons
output pwm, pwm_inv, pwm1, pwm2, pwm3, pwm4; // Five sets of PWM and one set of its compliment
wire [3:0] dc_w;
wire clk_w, oscena_w, dc_clk_w, pwm_clk_w, pwm1,pwm2,pwm3,pwm4,pwm_inv;
assign pwm1 = pwm;
assign pwm2 = pwm;
assign pwm3 = pwm;
assign pwm4 = pwm;
assign pwm_inv = !pwm;
assign oscena_w = 1;         //Enabling internal UFM oscillator
    altufm_osc0_altufm_osc_1p3 u1 (.osc(clk_w), .oscena(oscena_w));
clk_gen u2 (.osc(clk_w), .duty_cycle_clk(dc_clk_w), .pwm_clk(pwm_clk_w));
    duty_cycle u3 (.up(up), .dn(dn), .duty_cycle(dc_w), .clk(dc_clk_w));
    pwm_gen u4 (.duty_cycle(dc_w), .clk(pwm_clk_w), .pwm(pwm));
endmodule
/*Instantiation of UFM oscillator for utilizing built in clock*/
`timescale 1 ps / 1 ps
//synopsys translate_on
module altufm_osc0_altufm_osc_1p3
  osc,
  oscena) /* synthesis synthesis_clearbox=1 */;
  output  osc;
  input  oscena;
  wire wire_maxii_ufm_block1_osc;
  maxii_ufm  maxii_ufm_block1
  .arclk(1'b0),
  .ardin(1'b0),
  .arshft(1'b0),
  .bgpbusy(),
  .busy(),
  .drclk(1'b0),
  .drdout(),
  .drshft(1'b0),
  .osc(wire_maxii_ufm_block1_osc),
  .oscena(oscena)
  `ifdef FORMAL_VERIFICATION
  `else
  // synopsys translate_off
  `endif
  .drdin(1'b0),
  .erase(1'b0),
  .program(1'b0)
  `else
  // synopsys translate_on
  `endif
  .ctrl_bgpbusy(),
  .devclrn(),
  .devpor(),
  .sbdin(),
  .sbdout()
  defparam
    maxii_ufm_block1.address_width = 9,
    maxii_ufm_block1.osc_sim_setting = 300000,
    maxii_ufm_block1.lpm_type = "maxii_ufm";
  assign
    osc = wire_maxii_ufm_block1_osc;
endmodule //altufm_osc0_altufm_osc_1p3
* Clk_gen module for generating reduced frequencies from UFM Osc
  and to make suitable for generating duty cycle data clock and
  PWM generating clock
module clk_gen(osc, pwm_clk, duty_cycle_clk);
input osc;
output pwm_clk, duty_cycle_clk;
reg [18:0] count;
initial count=19'b0000000000000000000;
reg duty_cycle_clk;
reg pwm_clk;
always @ (posedge osc)
  begin
    count <= count + 1;
    pwm_clk <= count[10];
    duty_cycle_clk <= count[18];
  end
endmodule
* Generates 4 bit duty cycle word, each count (6.25%) corresponding to
 1 of 16 duty cycle percentages
module duty_cycle (up, dn, clk, duty_cycle);
input up, dn, clk;
output [3:0] duty_cycle;
initial duty_cycle=4'b0000;
reg [3:0] duty_cycle;
always @(posedge clk)
  begin
    if (!up)begin
      if (duty_cycle!=4'b1111)   // upward limit
        duty_cycle <= duty_cycle +1;
    end else begin
      if (!dn)begin
        if (duty_cycle!=4'b0000) // downward limit
          duty_cycle <= duty_cycle -1;
      end
    end
  end
endmodule
* PWM generating module, uses duty cycle value from duty_cycle module
module pwm_gen (clk, duty_cycle, pwm);
input clk;
input [3:0] duty_cycle;
output pwm;
reg [3:0] count;
reg pwm, pwm_temp;
initial
begin
count=4'b0000;
pwm=1'b0;
end
always @ (posedge clk)
begin
count = count+1;
if (count == duty_cycle) pwm = pwm_temp;
else
begin
if (count < duty_cycle)
begin
pwm = 1'b1;
pwm_temp = pwm;
end
else if (count > duty_cycle)
begin
pwm =1'b0;
pwm_temp = pwm;
end
end
end
endmodule
OABBA1
And I want to delay the pwm4 with 100ns from the pwm , how can i do the D flip flop to do that
thank you
ak6dn
Valued Contributor III
Do get a 100ns delay it depends on your clock period. If it is 20ns (50MHz) then a 5 stage D FF shift register will delay a signal by 100ns (5 clock periods).
You can easily code this in verilog or Altera even has an IP block you can use (ALTSHIFT_TAPS, but it is really overkill for what you need to do).
