FPGA Intellectual Property
6663 Discussions
Hi, i am trying to configure the external phy from CPU via MDIO slave but i am able to read even address in phy registers but not able to read odd address registers from phy.
DheeraJ
In Avalon Address bit[0] is read/write access so even if i want to read the address 0x09(1001). it is checking bit[0] and it is giving write access.
so please suggest us how to read odd registers from CPU via MDIO slave.
AnandRaj_S_Intel
Hi Dheeraj,
Is your base address and offset address set correctly on software?
Also please refer to sessions 9.4 & 9.2.4. from below link
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf
Check knowledge-base solutions from below link
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd10052010_44.html
Anand
DheeraJ
Hi Anand,
Base address and offset address is correct, because i am able to access(read) PHY Registers.
this sessions 9.4 & 9.2.4. is related to Ethernet MDIO but in my design i am using MDIO Slave. This is the different IP and he is acting as a slave to CPU.
on processor side we have only MDIO MDC lines. so we cannot use Ethernet MDIO .
Dheeraj
AnandRaj_S_Intel
Hi Dheera,
Can you share the user guide?
DheeraJ
Sure Anand,
please find the below attached document.
AnandRaj_S_Intel
Presently I don't have access to the IP I will try to get.
Meanwhile, try to use a signal tap for debugging & share images.
Anand
AnandRaj_S_Intel
Hi Dheeraj,
Apologies, We can't provide any information or help in debugging the third party IP.
For further support on third-party IP's,We recommend you to contact the IP vendor.
Anand
