FPGA Intellectual Property
6669 Discussions
How could I generate Example design of S10 PCIe GEN 2X4 with DMA option.
LChen23
Dis anybody create a example design from IP catalog which have DMA option enable? I only could see PIO option.
and in 'Intel® Stratix® 10 Avalon-ST
Interface for PCIe Solutions User
Guide', it mentions a Chaining DMA example , how could I get this example in S10 Device ?
BoonT_Intel
Hi Sir, Will it work if you just set the PCIe IP GUI with Gen2x4 and turn on DMA option. Then generate the example design on the top right corner?
LChen23
yes, it seems no DMA option at example design tap, only PIO in quartus 19.3pro.
BoonT_Intel
I also do not see any PIO under example design tab. Usually the example desingn is based on the available setting on the IP. Since there is no DMA design at this moment, so no PCIe with avmm-dma example design yet.Capture.PNGpio.PNG
