FPGA Intellectual Property
6669 Discussions
How to define the NULL descriptor in SGDMA
I use the SGDMA in TSE MAC.
As its document said, the last descriptor in the descriptor chain must be a
NULL descriptor. But I wonder how to define the NULL descriptor.
I define it in following way:
alt_sgdma_descriptor* tx_descriptor = (alt_sgdma_descriptor*)DESCRIPTOR_MEN_BASE;
alt_sgdma_descriptor* tx_descriptor_ = (alt_sgdma_descriptor*)(DESCRIPTOR_MEN_BASE + ALTERA_AVALON_SGDMA_DESCRIPTOR_SIZE);
alt_avalon_sgdma_construct_mem_to_stream_desc(tx_descriptor, tx_descriptor_, read_buffer, 256, 0, 1, 1, 0);
alt_avalon_sgdma_construct_mem_to_stream_desc(tx_descriptor_, (alt_sgdma_descriptor*)NULL, read_buffer, 256, 0, 1, 1, 0);
where tx_descriptor is the first descriptor, and tx_descriptor_ is the second(also the last descriptor) descriptor,.
I define the NULL descriptor use (alt_sgdma_descriptor*)NULL
Is that right?
I also had this question, and I am not sure what is the correct answer.
I *think* that a null descriptor is the (last) descriptor with the OWNED_BY_HARDWARE bit set. It's addresses and length are "don't cares".
I think the SG DMA engine will stop upon reaching this descriptor.
The documentation is not quite clear on this.
Leon.
your right leon
Correction:
- the null descriptor is the last descriptor with the OWNED_BY_HARDWARE bit _cleared_. (not set as I typed earlier).
Addition:
- the null descriptor addresses and length are "don't cares", as the SG DMA engine will not perform a DMA transfer for this last descriptor.
Can someone comment if this is correct or not??
likewise : That is correct and the alt_avalon_sgdma_construct_* macros takes care of this.
It always sets the "next" descriptor to NULL.
