FPGA Intellectual Property
6673 Discussions
How to divide a clock by two without using a PLL?
corestar
I'm using the Altera Tri-Mode EMAC for 10/100 Ethernet with MII interface to the Phy. This uses 25 MHz tx_clk and rx_clk generated by the Phy and going to the EMAC. These clocks do NOT use dedicated clock inputs. The EMAC puts them on clock nets using ALTCLKCTRL as follows:
I want to use a Phy with an RMII interface which has a single 50 MHz clock from the Phy. I have an RMII to MII bridge which generates tx_clk and rx_clk. I can of course use a PLL, but that requires a dedicated clock input and I'm short on pins.
So I'm looking for another way. On Xlinx, I can use a BUFR which allows dividing. So far on Altera, the only solution of come up with is to use an ALTCLKCTRL fed by a registers:
----------------------------------------------------------------------------- -- Divide the RMII clock by two ----------------------------------------------------------------------------- mii_clk_proc : process begin wait until rising_edge(rmii_clk); -- 50 MHz clock from Phy clk_div2 <= not clk_div2; -- 25 MHz "clock"   end process;     -- Drive ALTCLKCTRL to put clk_div2 on globacl clock rmii_clk_ctrl : component phy_clk_ctrl port map ( inclk => clk_div2, outclk => mii_clk -- drives both tx_clk and rx_clk );
But this seems like a really bad way to do this. Any suggestions?
Another problem is that whether I use a PLL or the above, the EMAC is still using two ALTCLKCTRL as above. These really should not be needed.
SreekumarR_G_Intel
Hello David , Sorry for the late reply , Actually I am trying to find is there any IP for FPGA for the clock division. I didn't find any sorry if i missed out too. From the clk division RTL output connected ALTCLKCTRL IP which is looks me connected to the buffer, but still iam worried adding flop in between the clock will add more jitter or skew. I never tried the way iam suggesting, But I didnt see any other way. can you kindly let me know how i can help you further ? Thank you , Regards, Sree
corestar
Hello @sreekumar.regu.girijakumari​ ,
Yes, the clk_div2 register is adding alot of delay. About 8 ns. So I needed to add FIFO's to buffer between the MII clocks and RMII clock.
For the most part, Xilinx IP is incredibly cumbersome and poorly designed compared to Altera, but they have some nice features such as the BUFR. It occurred to me I might use the clk_div2 as an enable for the ALTCLKCTRL instead of the input. But in the end, it's probably best if I have enough PLL's and clock inputs to avoid the problem.
SreekumarR_G_Intel
Hello David , Can I know how inlculding enable signal for ALTCLKCTRL work ? Is that anything i can help you further regarding to the issues ? Thank you , Regards, Sree
corestar
@sreekumar.regu.girijakumari​ , Using the enable is not a good solution. I'm forced to use a PLL for this purpose.
