FPGA Intellectual Property
6670 Discussions
How to encrypt my own IP block
I have tried to look for this info but unsuccessfully so far.. I wonder if someone can help:
I want to create an IP block to a client that will be instantiated via sopc builder but I wouldn't want them the access to the source code. Is it possible to encrypt the contents in a similar manner as most all Altera IP is ?
Even obfuscating would help but I'm not sure how to best go about that.
try .qxp with a clear text instantiation wrapper which becomes the top level of the custom component for synthesis, and simgen to create a simulation netlist (.vo/.vho). you'll lose parameterization, but it should work otherwise (i haven't fully tested it, the method may need some tweaking):
using .qxp:
http://www.altera.com/support/kdb/solutions/rd06242008_7.html
using simgen:
http://www.altera.com/support/kdb/solutions/rd07132006_347.html
alternatively, you may try requesting the encryption tools from Altera through an SR
