- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I have tried to look for this info but unsuccessfully so far.. I wonder if someone can help:
I want to create an IP block to a client that will be instantiated via sopc builder but I wouldn't want them the access to the source code. Is it possible to encrypt the contents in a similar manner as most all Altera IP is ? Even obfuscating would help but I'm not sure how to best go about that.Link kopiert
1 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
try .qxp with a clear text instantiation wrapper which becomes the top level of the custom component for synthesis, and simgen to create a simulation netlist (.vo/.vho). you'll lose parameterization, but it should work otherwise (i haven't fully tested it, the method may need some tweaking):
using .qxp: http://www.altera.com/support/kdb/solutions/rd06242008_7.html using simgen: http://www.altera.com/support/kdb/solutions/rd07132006_347.html alternatively, you may try requesting the encryption tools from Altera through an SR
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
