FPGA Intellectual Property
6670 Discussions
How to handle such warning message of UniPHY IP
XQSHEN
Use DDR2 controller with UniPHY
Integerate in platform design with NIOS.
Device used: Max10, 10M16DCU324I7G
Start analysis & Synthesis
NurAida_A_Intel
Hi Sir,
It seems to be a variable declaration issue and connectivity issue. I am suspecting this attributed to the warning.
Can the fitter compilation complete without error?-- If Fitter is Passing without error, then you can safely ignore the synthesis warnings.
You may find it useful to run the example design first, check the connection to help understanding and compare with your design.
I am attaching a word document which I centralized all the warnings listed with “CAUSE” and “ACTION” to help handle the warnings.
Hope this helps.
Aida
NurAida_A_Intel
Hi Sir,
As there has been no update from you recently, I am assuming that the information I provided has helped you to resolve your issue. I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
XQSHEN
I still have problem , but I don't find where can set it in assignment editor.1.JPG
NurAida_A_Intel
Hi Sir,
You can refer to page 28 of this Quartus handbook --> https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii5v2.pdf
Please follow the steps provided to assign the Output Enable Group option.
