FPGA Intellectual Property
6670 Discussions
How to make DDS with NCO megacore function?
I try to make square wave with NCO Megacore Function as below.
But, The square wave is not good for use like dds.
How to make square wave like ad9850 dds
----- below is VHDL Code ---------
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity dds is
port (
phi_inc_i : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
clk : IN STD_LOGIC;
reset_n : IN STD_LOGIC;
clken : IN STD_LOGIC;
freq_mod_i : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
fsin_o : OUT STD_LOGIC_VECTOR (21 DOWNTO 0);
out_valid : OUT STD_LOGIC;
square : out std_logic
end dds;
architecture behav of dds is
component nco
PORT (
clk : IN STD_LOGIC;
end component;
signal f_sin : std_logic_vector(21 downto 0);
begin
the_nco_is : nco port map (
phi_inc_i => phi_inc_i,
clk => clk,
reset_n => reset_n,
clken => clken,
freq_mod_i => freq_mod_i,
fsin_o => f_sin,
out_valid => out_valid
fsin_o <= f_sin;
the_comparator_is : process(clk, reset_n)
begin
if reset_n = '0' then
square <= '0';
elsif rising_edge(clk) then
if f_sin > "1000000000000000000000" then
square <= '1';
else
square <= '0';
end if;
end if;
end process;
end behav;
why not just use a counter/comparator type circuit? an NCO is not a good way to generate a square in both functionality and resource usage
--- Quote Start ---
--- Quote End ---
In which regard it's "not good"?
Waste of resource can be avoided, if you design a simple fractional frequency divider, following the DDS phase accumulator principle. But it's output will be time discrete, only switching at the input clock edge. In other words, it has a jitter.
If you intend an analog timing interpolation, as provided by the comparator output of the said DDS chips, you can't avoid the complete DDS effort, the sine DAC, analog filter and cocmparator.
--- Quote Start ---
--- Quote End ---
Is there any possible way to build the dds without nco.
I just use nco for variable clock.
--- Quote Start ---
--- Quote End ---
I want to design DDS(Direct Digital Synthesizer) with nco (for variable sine wave) and comparator (for clock generation). Is this way right for variable clock generator?
You're requirements aren't clear to me.
Do you need the sine output or only a variable clock?
Do you need a low jitter, analog interpolated clock or would a fractional clock be sufficient, as generate by your above example code? In the first case, you need all the analog stuff, e.g. a DAC and a low-pass filter, and using a DDS chip means less effort.
--- Quote Start ---
--- Quote End ---
I just want to design clock generator like dds with following specs.
Bandwidth : 50MHz
frequency resolution : 0.5Hz
Is above possible to use nco and comparator without analog stuff, e.g. a DAC, LPF and Comparator.
it wasn't clear that you wanted pulse and sine outputs. in this case i recommend building your own NCO so you have access to the phase accumulator output where you can more easily derive a pulse wave
The phase accu isn't more than
accu :unsigned (NCO_W-1 downto 0); freq :unsigned (NCO_W-1 downto 0); ... process(clk); begin if rising_edge(clk) then accu <= accu + freq; end if; end process, square <= freq(NCO_W-1);
Review the NCO MegaFunction manual for a detailed description.
