FPGA Intellectual Property
6670 Discussions
How to properly constrain the PFL ? Differences between 2 docs. Which one is right?
Knug
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
https://www.intel.com/content/www/us/en/programmable/documentation/sss1411439280066.html
Differences in below constraints between the 2 docs. Which constraints are right ?
flash_nce
flash_addr
flash_data
fpga_data
fpga_dclk
Knug
Noticed today (12 days later) after I opened the 2 docs again that you changed one of them to match the other BUT I never received a reply from you to let me know that you did this.
Knug
Both documents state now :
eg   https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf  on page 28 :
   Bidirectional synchronous:  flash_data     Read mode (PFL to Flash ROM) is listed here on page 28.
        set_max_delay -from <port> -to pfl_clk
Is this right ?
PFL to Flash ROM direction looks to be output from the PFL (ie flash_data is out for READ mode. Isn’t this the case?) so the set_max_delay constraint suggested above should be :
     set_max_delay -from pfl_clk -to <port>
Isn’t this the case here ?
Knug
Or I think :
Bidirectional synchronous:  flash_data     Read mode (Flash ROM to PFL) should be listed here on page 28 and NOT PFL to Flash ROM
        set_max_delay -from <port> -to pfl_clk         IS THEN CORRECT
Write Mode should then state (PFL to Flash ROM)  and NOT Flash ROM to PFL
Is this correct?
Knug
No reply here to this.
I also sent same message to the following private email BUT got back :
Delivery has failed to these recipients or groups:
noreply@community-mail.intel.com (noreply@community-mail.intel.com)
Your message couldn't be delivered. Despite repeated attempts to deliver your message, querying the Domain Name System (DNS) for the recipient's domain location information failed.
Knug
Wrt :
fpga_dclk constraint for input clock to DCLK ratio = 1  (see page 29)
create_generated_clock - source pfl_clk -invert <fpga_dclk_port>
I have used same constraint as above BUT have the following question :
Q/  Is there a special reason to why -invert is suggested here ?
Like a reply to this please.
SyafieqS
Kevin
Im checking this and let you know.
