FPGA Intellectual Property
6670 Discussions
How to use Avalon Bus by Eclipse?
Gyud0
Hey,
I would like to know how to write and read data by a C code that runs by Eclipse and uses the Avalon Bus .
I designed the entity below that contains the Avalon Bus ports,clock,reset and the outputs to my inner design (out1,out2,out3) and output to NIOS (out4).
The whole design by Qsys include: NIOS2, my design,JTAG UART,On chip memory and System ID.
The addresses range for my design by Qsys is 0x401020-0x40102F, hence 16 bytes of addresses,thus 4 addresses of 32bit each.
I wrote a C code that out2 will get the value 3 , bit it doesn't work. in Eclipse Debug mode I see the value 0 at the whole addresses space, but I got the value 0x01241000" at address 0x40103C (outta from address space of my design).
Thank you very much !
My Avalon Bus entity :
library ieee;
use ieee.std_logic_1164.all;
library ieee.std_logic_arith.all;
entity avalon_entity is
port(
clk,rst_n: in std_logic;
avs_read,avs_write: in std_logic;--FROM NIOS
avs_readdata: out std_logic_vector(31 downto 0); --to NIOS
avs_writedata: in std_logic_vector(31 downto 0); --FROM NIOS
avs_address: in std_logic_vector(1 downto 0);--FROM NIOS
out1,out2,out3,out4:out std_logic_vector(31 downto 0)
end entity avalon_entity;
architecture behave of avalon_entity is
signal reg1,reg2,reg3,reg4: std_logic_vector(31 downto 0);
begin
out1<=reg1;
out2<=reg2;
out3<=reg3;
out4<=reg4;
process(clk,rst_n)
begin
if rst_n='0' then
reg1<=(others=>'0');
reg2<=(others=>'0');
reg3<=(others=>'0');
reg4<=(others=>'0');
elsif rising_edge(clk) then
if avs_write='1' then
case conv_integer(avs_address) is
when 0=> reg1<=avs_writedata;
when 1=> reg2<=avs_writedata;
when 2=> reg3<=avs_writedata;
when others=> NULL;
end case;
end if;
if avs_read='1' then
when 0=> reg4<=avs_readdata;
when others=> NULL;
end case;
end if;
end if;
end process;
end behave;
The C code:
#include<stdio.h>
int main()
IOWR(0x401020,0x04,0x03);
printf("0x401024=%u\n",0x0);
The output is :
0x401024=8650772.
This is a garbage value.
Gyud0
I made it. Thank you anyway =)
