FPGA Intellectual Property
6673 Discussions
How to use Nios ↔ Logic (Avalon mm Burst Transfer)
jjang
i wanna Burst Transfer or Steamming data communication Between Logic and NIOS.
now i tried Simple Avalon mm transfer but lots of Overhead.
Addrss
Read_Data,  Write_Data
Write, Read
ShengN_Intel
May I know any further update or consideration?
Sheng
jjang
i just finish read Avalon mm Interface Spec Sheet . and i tried to make it.
1.  I Dened like that Nios..
2. Nios Connection
 when Connection Initial Nios Core Settings don't have Burst Count [32] so i tried to make it
 - nios Caches and Memory Interfaces Data Cache Add Burstcount signal to data_master → Enable
 - Avalon MM -Slave          <---->    NIOS Core Data Master
 : Burst_Count [32]          <----->  : none
 : ReadDataValid [1]        <----->  : ReadDataValid [1]
: Addr [8]                            <---->  : Addr [14] 
: Read [1]                            <----> : Read [1]
: Read_Data[32]                <----> : Read_Data[32]
: wait_Request [1]            <----> : wait_Request [1]
: write [1]                           <----->: write [1]
: Write_Data [32]          <----->: Write_Data [32] 
:   none                               <-----> : Byte_Enable [4]
:  none                                 <----> : debug_mem_slave_debugaccess_to_roms [1]
for burst transfer is it good connection?
ShengN_Intel
How about the byteenable signal (Master -> Slave)?
ShengN_Intel
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
