FPGA Intellectual Property
6669 Discussions
I am trying to create a Viterbi IP block and use in my Arria V GZ design. I am not running an Avalon bus internal. I see that when I choose the Viterbi IP from the DSP/Error Detection and Correction section, it is generated using Qsys.
GRose12
I have 2 questions:
  1. Can I directly connect to this IP and not use an Avalon Bus interface
  2. Can I simulate this core in ModelSiim
CheePin_C_Intel
As I understand it, you have some inquiries related to the Viterbi IP in AVGZ devices. Please see my responses to your inquiries as following:
[CP] Yes, you can directly connect this IP in your RTL. Note that the signals at the interface would need to follow the Avalon requirement ie SOP, EOP, Valid and etc.
[CP] Yes, you can generate simulation example design through IP Paramemter Editor -> Generate -> Generate Example Design.
Please let me know if there is any concern. Thank you.
Chee Pin
GRose12
Chee, Thank you for the information. I followed your instructions and I worked with Steve Zack this morning who is a Arrow/Intel FAE for my territory. He helped me understand that I wanted to use the Viterbi IP in Continuous Mode, so I have changed the IP setup. I have built a ModelSim project to try to simulate the IP and I am still having issues. I don’t see in the ug_viterbi-compiler.pdf document exactly how to run in continuous mode. On page 35 and 36 are the only timing diagrams but they are not for continuous mode. I have setup my ModelSim test bench and here is my waveform output showing that the logic flow with decbit, source_val and decbit being undefined. [cid:image003.png@01D5DB78.CBFF1CB0] My first question is will I be able to simulate the Viterbi IP in ModelSim. If so, what files do I need to include. Best regards, Glenn Rosenthal Ulyssix Technologies, Inc. DATT Summit Phone: 301-846-4800 ext. 301 Fax: 301-846-0686 www.ulyssix.com<http://www.ulyssix.com/> www.dattsummit.com<http://www.dattsummit.com/> "Where technology soars" [cid:image004.jpg@01D5BEF7.9952AEF0]<http://www.dattsummit.com/>[cid:image005.png@01D5BEF4.A5AE7830]<http://www.dattsummit.com/floor-plan>
CheePin_C_Intel
Hi Glenn,
Thanks for your update. As I understand it, you are using Viterbi IP in Continous Mode. For your information, I have tested configuring the Viterbi IP in Continous Mode (left other settings as default) and generated the example design from the IP in Q17.0Std. Note that I do not have AV database installed in my local PC and therefore I am generating for CV devices.
After generating the design, I do the following to simulate the example design:
1. Open Modelsim and change working directory to the "simulation_scripts\mentor"
2. Type "source msim_setup.tcl"
3. Type "ld" to start compilation
4. Add the targeted signals to Wave and run the simulation
For your information, the simulation seems to be working fine. I have emailed you the simulation example (viterbi_ii_0_ex_des_cont.zip) that I am running for your reference.
Chee Pin
GRose12
Chee, Thank you for your answer. I was not able to work on this subject today. I will try your suggestion tomorrow and get back with you. I greatly appreciate your prompt reply. Best regards, Glenn Rosenthal Ulyssix Technologies, Inc. DATT Summit Phone: 301-846-4800 ext. 301 Fax: 301-846-0686 www.ulyssix.com<http://www.ulyssix.com/> www.dattsummit.com<http://www.dattsummit.com/> "Where technology soars" [cid:image004.jpg@01D5BEF7.9952AEF0]<http://www.dattsummit.com/>[cid:image005.png@01D5BEF4.A5AE7830]<http://www.dattsummit.com/floor-plan>
CheePin_C_Intel
Thanks. Feel free to keep me posted.
