FPGA Intellectual Property
6673 Discussions
I want to Erase CFM0,but it seems like flash didn't response.
KWang97
无标题.pngI want to Erase CFM0,but it seems like flash didn't receive my command. Why?
Below are code:
  CFM1 : CFM
    port map(
         clock => ssClk,
         reset_n => ssRst,
         avmm_data_addr => slv17avmm_data_addr,
         avmm_data_read => slavmm_data_read,
         avmm_data_writedata => slv32avmm_data_writedata,
         avmm_data_write => slavmm_data_write,
         avmm_data_readdata => slv32avmm_data_readdata,
         avmm_data_waitrequest => slavmm_data_waitrequest,
         avmm_data_readdatavalid => slavmm_data_readdatavalid,
         avmm_data_burstcount => B"01",
         avmm_csr_addr => slavmm_csr_addr,
         avmm_csr_read => slavmm_csr_read,
         avmm_csr_writedata => slv32avmm_csr_writedata,
         avmm_csr_write => slavmm_csr_write,
         avmm_csr_readdata => slv32avmm_csr_readdata
FlashErase : process( ssClk )
  begin
    if rising_edge( ssClk ) then
      slv32MSG_ID_Old <= slv32MSG_ID;
      case stFlashEraseState is
        when ST_ERASE_IDLE =>
          slEraseOK <= '0';
          if slv32MSG_ID = X"00001000" and slv32MSG_ID_Old /= X"00001000" then
            stFlashEraseState <= ST_ERASE_UNPROTECT;
            slavmm_csr_write <= '1';
            slavmm_csr_addr <= '1';
            slv32avmm_csr_writedata <= X"F7FFFFFF";
          end if;
        when ST_ERASE_UNPROTECT =>
          stFlashEraseState <= ST_ERASE_START;
        when ST_ERASE_START =>
          stFlashEraseState <= ST_ERASE_WAIT;
          slv32avmm_csr_writedata <= X"F7DFFFFF";
        when ST_ERASE_WAIT =>
          slavmm_csr_write <= '0';
          slavmm_csr_read <= '1';
          slavmm_csr_addr <= '0';
          if slv32avmm_csr_readdata(1 downto 0) = B"00" and slv32avmm_csr_readdata(3) = '1' then
            stFlashEraseState <= ST_ERASE_IDLE;
            slavmm_csr_read <= '0';
            slv32avmm_csr_writedata <= X"FFFFFFFF";
            slEraseOK <= '1';
          end if;
        when others =>
          null;
      end case;
    end if;
  end process FlashErase;
JohnT_Intel
  1. May I know how do you connect the clk to the On Chip Flash IP?
  2. Is it from internal Oscillator or clk pin?
  3. What is the clk frequency used?
  4. Could you read the status register (CSR_ADDR = 0x0) after you disable the write protection and after you execute sector erased?
KWang97
Thanks a lot!
I have solved this and the problem is caused by wrong reset signal.
JohnT_Intel
I am glad to hear that the issue has been resolved and is due to the reset signal not routed correctly.
