Hi everybody,
I have some problems with the IP Ethernet 10 Gbps and the High Speed Mezzanine Connectors. Configuration :
FPGA Arria GX ======> PC with HSMC card
with Eth 10 Gbps HSMC (Windows recognize it like a Ethernet card)
But I don't see anything in Wireshark. I think the code is ok (works in simulation, IP Ethernet settings is ok, ...) but I don't really understand how to connect the pins, so the problem must be here (I also move SW2 to switch JTAG/HSMC mode). According to the Arria GX Development Board, they are these pins :
- Transceiver transmit channels :
HSMA_TX_P(3:0)
HSMA_TX_N(3:0)
- Transceiver receive channels :
HSMA_RX_P(3:0)
HSMA_RX_N(3:0)
- Data bus :
HSMA_D(3:0)
HSMA_TX_D_P(16:0)
HSMA_TX_D_N(16:0)
HSMA_RX_D_P(16:0)
HSMA_RX_D_N(16:0)
- Clock output 0 :
HSMA_CLKOUT0
- Clock output 1 :
HSMA_CLKOUT_P1
HSMA_CLKOUT_N1
- Clock output 2 :
HSMA_CLKOUT_P2
HSMA_CLKOUT_N2
- Clock input 0 :
HSMA_CLKIN0
- Clock input 1 :
HSMA_CLKIN_P1
HSMA_CLKIN_N1
- Clock input 2 :
HSMA_CLKIN_P2
HSMA_CLKIN_N2
I tried to connect : - HSMA_TX_P and HSMA_TX_N to xaui_tx_data[3..0] (PCML) - HSMA_RX_P and HSMA_RX_N to xaui_rx_data[3..0] (PCML) - Input clocks to ouput clocks (LVDS) but doesn't work... How can I connect the IP to HSMC ? What is these 17 bits data bus signals ? Thanks
