FPGA Intellectual Property
6670 Discussions
In PCIe DMA reference design, export TX Slave interface to allow use in rest of FPGA
Extremely new to QSys and couldn't find good information by searching. :confused:
How do I export the TX Slave interface (TXS) in the attached QSys system to make it available to the rest of the FPGA design? I would like both the internal sources (rd_dcm_master and wr_dcm_master) and external sources (elsewhere in the FPGA) to be able to use this interface to master PCIe transactions. i.e., I would like QSys to create an arbiter and export one of the sources.
Thanks!
Hi
In order to export the TX Slave you need to create a pipeline bridge and export it out.
-First you connect the TX Slave to Master pipleline bridge
-Second export the Slave pipleline bridge
Hi
WaiMun
[‎10/‎30/‎2017 1:20 PM] Tan, Kenny Ker Wei:
(This message was posted on behalf of Intel Corporation)
Thank you!
