FPGA Intellectual Property
6672 Discussions
Intel PCIE multichannel DMA
10
Hi ,
I am using Multichannel DMA for PCIE Express and
Error: multi_pcie_intel_pcie_mcdma_0: add_hdl_instance: Can't create component type
while executing
"add_hdl_instance fpll_g3 $fpll_ip"
(procedure "::altera_pcie_s10_hip_common::declare_pllnphy_fileset" line 196)
invoked from within
(procedure "::intel_pcie_mcdma::fileset::declare_pllnphy_fileset" line 2)
invoked from within
(procedure "::intel_pcie_mcdma::module::elaborate" line 9)
invoked from within
i am getting above error because of this not able to create HDL
can you please give solution for that?
Rahul_S_Intel1
This case is been taken as private conversation.
Rahul_S_Intel1
Kindly note the P tile is not supported  H -tile devices is supported on the above configuration
