Hi out there!
So i got a Nios2/f License today and ported it into my existing Design. But when i flash the NiosII Program onto the FPGA the Processor frezzes. I commented the Interrupt init lines out and now it works. With the Nios II/e design the Interrupts_Init routines work with the NiosII/f they don´t. I included the "nios2_gen2_irq.h" and the "alt_irq.h" neither work with the NiosII/f Here are the Routines: void init_wiznet_connection_Lost(void) { /* Recast the edge_capture pointer to match the alt_irq_register() function * prototype. */ void* edge_capture_ptr = (void*) &edge_capture_wiznet_link; /* Enable first button interrupts. */ IOWR_ALTERA_AVALON_PIO_IRQ_MASK(WIZNET_LINK_BASE, 0x1); /* Reset the edge capture register. */ IOWR_ALTERA_AVALON_PIO_EDGE_CAP(WIZNET_LINK_BASE, 0x0); /* Register the interrupt handler. */ alt_ic_isr_register(WIZNET_LINK_IRQ_INTERRUPT_CONTROLLER_ID, WIZNET_LINK_IRQ, handle_wiznet_connection_Lost, edge_capture_ptr, 0x0); } //100 ms TIMER Interrupt initialization void init_timer_interrupt(void) { int* ptr; IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE, (1<<3) | (1 << 1) |(1 << 0)); IOWR_ALTERA_AVALON_TIMER_STATUS(TIMER_0_BASE,0); // Clear TO Bit(Reaching 0) IOWR_ALTERA_AVALON_TIMER_PERIODL(TIMER_0_BASE,(alt_u16)(100000000)); // 1 Sek Interrupt // 100 ms Interrupt IOWR_ALTERA_AVALON_TIMER_PERIODH(TIMER_0_BASE,(alt_u16)( (100000000) >> 16 )); // 1 Sek Interrupt alt_ic_isr_register(TIMER_0_IRQ_INTERRUPT_CONTROLLER_ID, TIMER_0_IRQ,handle_timer_interrupts, ptr, 0x0); //Register Interrupt IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE,(1<<2) | (1 << 1) | (1 << 0) ); //Start Timer, IRQ enable, Continuous enable } //Wiznet initialization void init_wiznet_interrupts() { /* Recast the edge_capture pointer to match the alt_irq_register() function * prototype. */ void* edge_capture_ptr = (void*) &edge_capture_wiznet; /* Enable first button interrupts. */ IOWR_ALTERA_AVALON_PIO_IRQ_MASK(WIZNET_NINT_BASE, 0x1); /* Reset the edge capture register. */ IOWR_ALTERA_AVALON_PIO_EDGE_CAP(WIZNET_NINT_BASE, 0x0); /* Register the interrupt handler. */ alt_ic_isr_register(WIZNET_NINT_IRQ_INTERRUPT_CONTROLLER_ID, WIZNET_NINT_IRQ, handle_wiznet_interrupts, edge_capture_ptr, 0x0); } Any ideas on that Topic? Thank you very much!Link Copied
Check if the IRQ hardware connections are still there in Qsys
The IRQs were still connected so i simply deleted the Nios II from the Qsys design and implemented it again. Now it works. Thanks again!
