FPGA Intellectual Property
6670 Discussions
Is Transceiver Toolkit compatible with 8B10B encoder/decoder ?
I want to test a transceiver link on a Stratix V GX SI Dev Board.
Firstly, I have successfully run the altera design example "sv_4ch_32b_6445mbps" with Quartus II v13.0SP1.
Then, I have modified the example, mainly by modifying the xcvr_custom_phy IP in QSys:
- different data rate and clock
- enabling 8B10B encoder/decoder
- adjusting the word alignment pattern accordingly...
I have successfully re-generated the design in QSys and then re-compiled the design in Quartus.
Then I have tested the modified design with the toolkit, I have obtained the following results:
- The Tx transceiver seems to run correctly
- For the Rx transceiver, the indicator "RX CDR locked to data" is green but the Receiver Channel remains in Yellow with the following indication: "TOOLTIP_STATUS_RECEIVER_CHECKING_BUT_NOT_LOCKED". ..
The behaviour is similar with and without the check of option "enable word aligner".
By looking for a solution, I have read again the chapter 11 of the Altera document "http://www.altera.com/literature/hb/qts/qts_qii5v3.pdf".
In the table 11-4 page 220, IP core configuration is provided.
For the Custom PHY, the following configuration is indicated:
-Set lanes, group size, serialization factor, data rate, and input clock frequency to match your application.
-Turn on Avalon data interfaces
-disable 8b/10b
-Set Word alignment mode to manual
-Disable rate match FIFO
-Disable byte ordering block
Based on this information, should we conclude that it is not possible to use 8B10B with the Transceiver Toolkit ?
Thanks in advance for your help!
Best Regards
Mike
if I am experiencing the same problem and I have reached the same conclusion, am I doing something wrong? I am using a Cyclone V so I am not looking at eye diagrams, just link ber.
Thanks in advance
--- Quote Start ---
Thanks in advance
--- Quote End ---
I made this post a long time ago and now I'm working on different subject... so it is difficult to remember...
As far as I remember, 8B10B is problematic for Transceiver Toolkit.
However, I may found a functional test configuration using the "serial bit comparator" mode...
Sorry for this poor support...
Bye
Mike
thanks, it is a good hint to start exploring new possibilities.
