FPGA Intellectual Property
6670 Discussions
CORDIC vs. Matlab results
I am using Altera CORDIC for ATan2 and SinCos functions. I am applying the same test vectors to the CORDIC ATan2 and SinCos functions testbench and to the ATan2 and SinCos Matlab Models. I see about 10% of samples don’t match between CORDIC functions and Matlab outputs. For both Matlab and CORDIC I use the same S18,17 inputs for ATan2; S11,8 output for ATan2; S11,8 input for SinCos; S10,8 output for SinCos.
Any idea why it happens?
Mike
cordic gives approximate result and its accuracy depends on number of internal iterations(rotations).
--- Quote Start ---
--- Quote End ---
Kaz,
Thanks!
Could you please recommend application notes or/and user manuals I could learn more how to increase CORDIC accuracy?
--- Quote Start ---
Kaz,
Thanks!
--- Quote End ---
I understand you are using Altera's cordic but can't find any link to its manual.
Xilinx has cordic ip and its manual at:
http://www.xilinx.com/support/documentation/ip_documentation/cordic/v6_0/pg105-cordic.pdf
This should give you some idea about available settings.
there is also a cordic ip at opencores. It is not difficult to write your own targeting specific trigonometric function.
The following pdf provides a good basis:
http://www.ee.ic.ac.uk/pcheung/teaching/ee3_dsd/crdcsrvy.pdf
