FPGA Intellectual Property
6673 Discussions
FIR compiler II syntax error
I am using quartus 15.1 to generate a fir ii core. I chose the verilog option for the cores language.
I am using candace tools to elaborate and simulate a design with the generated FIR II core.
Here are the options I am using when I elaborate and simulate my design
irun: 14.10-s021: (c) Copyright 1995-2015 Cadence Design Systems, Inc.
TOOL: irun 14.10-s021: Started on Jun 23, 2016 at 16:49:19 EDT
irun
-cdslib cds.lib
-hdlvar hdl.var
-access +c
-smartorder
-status
-v93
-work worklib
-input scripts/tb_tx_filters.tcl
-top tb_tx_filters
-vlogext .vo,.VO,.vp,.VP
-vhdlext .vho,.VHO
-nostdout
-clean
-l logs/irun.log
-makelib shlslib
During the elaboration phase I get the following error../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd:
max_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '0', others => '1');
ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,143|54): non-locally static or null range choice must be only choice [7.3.2.2].
ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,143|70): non-locally static or null range choice must be only choice [7.3.2.2].
min_val <= (IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 => '1', others => '0');
ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,144|54): non-locally static or null range choice must be only choice [7.3.2.2].
ncvhdl_p: *E,AGNLSC (../../../../ip_cores/core_files/fir_interpolate8/fir_interpolate8_sim/auk_dspip_roundsat_hpfir.vhd,144|70): non-locally static or null range choice must be only choice [7.3.2.2].
errors: 4, warnings: 0
This is the section of the file auk_dspip_roundsat_hpfir.vhd causing the error.
-- msb : trunc/saturation
remove_msb: if REM_MSB_BIT_g > 0 generate
signal min_val, max_val : std_logic_vector(IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 downto 0);
begin
trunc_msb: if REM_MSB_TYPE_g = "trunc" generate
begin
data_msb <= data_lsb(IN_WIDTH_g-REM_LSB_BIT_g-REM_MSB_BIT_g-1 downto 0);
dataout <= data_msb;
valid <= valid_lsb;
end generate trunc_msb;
sat_msb: if REM_MSB_TYPE_g = "sat" generate
data_msb <= std_logic_vector(max_val) when signed(data_lsb) > signed(max_val) else
std_logic_vector(min_val) when signed(data_lsb) < signed(min_val) else
msb_p : process (clk, reset_n)
begin
if reset_n = '0' then
dataout <= (others => '0');
valid <= '0';
elsif rising_edge(clk) then
if valid_lsb = '1' then
end if;
valid <= valid_lsb;
end if;
end process msb_p;
end generate sat_msb;
end generate remove_msb;
how can i resolve these errors so my design will elaborate the fir ii core?
