FPGA Intellectual Property
JPEG Compression
HI
am using IP core from opencores.org : JPEG Encoder core
facing this issue :
# ** Error: (vcom-7) Failed to open design unit file "../design/common/JPEG_PKG.VHD" in read mode.#
can any 1 solve this issue !!!
thanks in advance !!!!
This error means that modelsim doesn't find that file. You should check that you have all the required files and that they are at the correct place.
